Please help me about OOS of standby PGW
Hi experts,
I 'm installing 2 PGW 9.2.2 on 2 sunfire v120 (one disk on one sun). So I follow the guides on Cisco Install guide document.
The procedure I do as:
1 - Install Sun solaris 8
2 - Install Patch CSCOh015
3 - Install MGC software 9.2.2
4 - Install Patch CSCOh013
I configured the parameters on XECfgParm.dat as the guides of Cisco for redundant system.
2 PGW status is : active and OOS (Out Of Service). If a PGW run first, it will get Active. If I stop MGC in Active PGW,and after restart it will be on OOS, the other will be in active automatically.
2 PGW connected to SW 3500 Cisco via every eri0 of them.
I configured PGWs like: speed 100 and mode link: fullduplex
I check platform.log file on them. They showed that LinkA is not communicated.
I look forward to your helps and thanking for that
Best regards,
Silver
Re: Please help me about OOS of standby PGW
Check whether pom.sync is disabled.
Thanks A-vazquez, pom.sync on both PGW was set with true, is there any advise else ?
137
