Community Member
Point to point Bandwidth
dear sir
I am using Pont to point microsoft base VPN and using CCME on both side , i wanna know how much bandwidth will be used for 1 voice call from side A to side B with VPN ? and can i register Ip Phone From side A to Side B using CCME ?
I m currenly using 64 K link.
Your assistance will be hihgly appreciatable.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Point to point Bandwidth
A regular g.711 call takes almost 90 Kbps plus the VPN overhead.
Your call should work OK on 64 K links if you configure codec g711ulaw under ephone.
If the VPN is passing all the traffic OK, you can register phones across the link without problems.
1 REPLY
121
