Port with multi-vlan for voice and data??
Hi guys,
I've a situation where my VOIP and DATA on a different segments. Voice is 10.x.x.x riding on VLAN 701. And my data is 192.x.x.x riding on VLAN 100.
The problem occur when our receptionist PC have a software installed for call forwarding for our general line. This software need to be on the same vlan with the IP Phone vlan which is 701. If I put her PC on those vlan, she can't access
to our LAN which is vlan 100. So she can't check her email etc.
Can I know what is the options I have? Can I configured multi-vlan for her PC on the switch? We are using Cisco PoE 3560 switch. Thanks.
1 REPLY
Hall of Fame Super Gold
Re: Port with multi-vlan for voice and data??
on the L3 switch, you should have an IP address for both VLAN 701 and 100. So, the L3 switch is doing inter-VLAN routing.
This means, unless you have ACL blocking traffic, any device will be able to reach any other device, even on a different VLAN.
And, no matter where you put voice and applications, everything will work anyway.
154
