Community Member
problem configuring QOS for SIP on Cisco ASA
Hello !!
I had some noise in the VoIP sound, because there is some data which is uploading from our WAN link at the same time users are tolking on the IP Phone.
So I decided to configure QOS priority for SIP, but it seems that I wasn`t lucky this time, and I really hope that someone can tell me what wrong I did in my config which is written below:
below is my complette policy config as it is now:
priority-queue outside_wan
class-map Voice
match dscp ef
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect netbios
inspect tftp
inspect dns
inspect esmtp
inspect pptp
inspect ipsec-pass-thru
inspect sip
policy-map Voicepolicy
class Voice
priority
service-policy global_policy global
service-policy Voicepolicy interface outside_wan
My outside interface is called "outside_wan"
I hope someone can explain me what`s wrong in this config.
Thank You
Best regards
Silver
Re: problem configuring QOS for SIP on Cisco ASA
Do "show service-policy priority" and "show priority-queue statistics outside_wan" show a correct and working configuration? Is traffic being matched against the LLQ?
In the configuration of the priority queue "priority-queue outside_wan", you may need to change the values of the queue-limit and tx-ring-limit.
Please rate helpful posts.
Community Member
thank you for reply !!!
below is the show output :
ciscoasa# show priority-queue statistics outside_wan
Priority-Queue Statistics interface outside_wan
Queue Type = BE
Tail Drops = 0
Reset Drops = 0
Packets Transmit = 7971924
Packets Enqueued = 0
Current Q Length = 0
Max Q Length = 0
Queue Type = LLQ
Tail Drops = 0
Reset Drops = 0
Packets Transmit = 189321
Max Q Length = 0
ciscoasa#
so does the command look like, the one I should use instead of priority-queue outside_wan ??
Silver
The fact that packets are being transmitted from your LLQ suggests that traffic is being matched and placed in the correct queue in the service-policy. In which case, you may need to tweak the tx-ring-value and queue-limit values.
What is your WAN link? If you use an upstream router, then QoS need to be enabled there too, otherwise you're just ensuring the RTP packets leave the PIX before anything else.
Which ASA code are you running?
Community Member
I am running ASA 5505 ASA OS: 8.03 ASDM 6.03.
Nex router after my router is ISP Core router which is not under my control.
Cisco ASA I use now have static wan ip address and is connected to ISP`s CORE router.
So I would like to configure my ASA to priority SIP traffic...
Silver
What size is your WAN link, is it congested? If so, PIX QoS won't help, unless the ISP also honours the markings and queues appropriately.
Are you trying to LLQ your RTP streams or the SIP control messages?
Community Member
well I tryed to control messages first.
My wan link is 2 Mb upstream and 24 Mb downstream. And i see that I am able to upload 200 Kb/ps. so the bandwidth is not a problem.
Silver
Is that kilobits or kilobytes per second? A 2Mbit/s upstream equates to ~200KByte/s, so if your upstream is congested, then voice will suffer unless you can get your SP to LLQ the voice traffic as it leaves their router.
The bottleneck in the system is the 2Mbps upstream, not any FE interfaces on the ASA.
Please rate helpful posts!
Community Member
sorry it is 200 KB/ps, so you mean that this is not enough that I only configure qos on my cisco ASA ? I really don`t think so that my isp will help me.... unless you have any idea or sample config how can I accomplish this goal.
Silver
I think the point is it may not be enough. If your upstream bandwidth is congested (e.g. an FTP transfer is saturating the line), then there's not much you can configure to prioritise voice (as you're not in control of the next-hop device, and DiffServ using PHB), except maybe to shape other traffic so there is room for voice.
Community Member
I am thinking about this configuration:
access-list 101 permit tcp any any eq 5060
access-list 101 permit udp any any eq 5060
access-list 101 permit tcp any eq 5060 any
access-list 101 permit udp any eq 5060 any
Class-map match-any SIP
match access-group 101
Policy-map SIP
Class SIP
set dscp ef
priority percent 10
Interface ethernet 0/0.10
description outside
service-policy output SIP
so in other words the voip is not easy to handle, but in which case users can get VoIP working as it should is it possible at all ??
Community Member
but how I can have clean sound as water when I use the Skype ?? no problems at all I can upload what ever I will and I can still talk via SKYPE without any problems. But when I use SIP my linksys adapter which is connected to the Cisco ASA and my phone connected to this linksys adapter than I can`t use ip phone at all if I am uploading the sound is full of noises latency etc...... :(
Silver
Although it is perfectly possible to treat the SIP call signalling messages in a similar manner (although they are not usually priority-queued; more often they are marked as DSCP CS3 and assigned a minimum amount of guaranteed bandwidth). More bandwidth will be used by the actual voice RTP streams. Have you considered using a different codec, e.g. G.729 rather than G.711? I don't know a lot about Skype's codecs, but they may be more tolerant of delay and jitter.
Community Member
me either, i am not so familiar with skype, have tried it once. Well I`ll see what I can do here... I must figure out something.
What is wired in my mind is following :
When i stop any uploading from my network (ASA) than I have clean sound no problems at all EVEN if either me or ISP have configured any priority for the SIP traffic.. I can`t understand it at all.....:(
2508
