Problem CUCM and CUCMIMP
alvaropalmeirao
Hi all,
When i go to service ability -> TOOLS -> ControlCenter - Feature Services and select my CUCM IM & Presence server i get this error:
Connection to the Server cannot be established(Certificate Exception)
Anyone knows what it is and how to resolve?
Thanks in advance.
If you have DNS enabled try pointing to the DNS name of the server
Failing that try,
1. Clear browser cache, delete the certificate cache for the servers as well
2. Restart the Cisco Tomcat service (you can do this when SSH into the server)
3. Regenerate the server certificate and then restart the tomcat service (SSH also)
5 Replies 5
heathrw
Level 4
Level 4
Does this occur from all computers? also tried a different web browser?
Yes for both questions.
I dont know what to do.
Failing that try,
This solved my problem.
Jaime Valencia
Please post in the right place, this is VIDEO over IP
java
if this helps, please rate
