Problem to release FXO port
hi all.
I have 4 lines to the PSTN connected to a FXO card, the problem is when somebody in the PSTN call and hung before they answer the IP phone, the IP phone continuous ringing and the FXO port is not released, to stop ringing and release the port, in need to off-hook the IP Phone
the FXO card is a VIC2-4FXO
the voice-port configuration is:
voice-port 0/1/0
timeouts call-disconnect 1
timeouts ringing 30
timeouts wait-release 1
connection plar 1202
voice-port 0/1/1
timeouts ringing 30
voice-port 0/1/2
timeouts ringing 30
connection plar 1205
voice-port 0/1/3
timeouts ringing 30
1 ACCEPTED SOLUTION
Re: Problem to release FXO port
Have you tried using connection plar opx?
Silver
what's the software version which you are using ?
The Hardware and Software version:
Router 2811
IOS 12.4(4)XC SPSERVICESK9-M
CCME 4.0(1)
VIC2-4FXO
Hi, you need to ask to your provider to add the "Cut On Disconnect" option to each of your 4 lines. This option is also known as COD option.
I had this issue with Bell Canada (DMS-100)
Hi.
The problem is when I configure connection plar to a IP Phone, without connection plar the FXO port ir release correctly.
thanks
The "connection plar opx" resolve the problem
great aid
I know... The COD option will fix your issue
242
