Problem VOFR cisco 3810 and Cisco 1750
-I have a network with equipment 3810 Cisco and Cisco 1750 in topology in stars.
-The router central is a Cisco 3810 wthin a E1 connected to PBX
- other router in the network, have fxs wthin two port
- the network this working with vofr
- the problem is: from an equipment 1750 I can call to a Cisco 3810 but from an equipment 3810 I can not to a cisco 1750.
- but if I place debug in Cisco 1750 ( debug voice ccaip inout) I watch that the call this arriving
- the configurations de routers is OK
- please it can help me
Re: Problem VOFR cisco 3810 and Cisco 1750
We need to see the debug for that "debug voice ccapi inout" from 1750 for a call from 3810 with the config of 1750 too . It will show us the possible issue. Pl. post it here.
This is the information.
A call from the 3810 to Cisco 1750
Number telf 6250
-------------------Router Central Cisco 3810------------------
Sh ver, Sh run
sh ver
IOS (tm) MC3810 Software (MC3810-IS-M), Version 12.0(5)XK, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Thu 22-Jul-99 10:55 by linda
Image text-base: 0x00023000, data-base: 0x0091A30C
ROM: System Bootstrap, Version 12.0(1)XA4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: MC3810 Software (MC3810-WBOOT-M), Version 12.0(1)XA4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
LOS_COLORADOS uptime is 6 weeks, 4 days, 2 hours, 15 minutes
System image file is "flash:mc3810-is-mz_120-5_XK.bin"
Cisco MC3810 (MPC860) processor (revision 10.01) with 28672K/4096K bytes of memory.
Processor board ID 17037217
PPC860 PowerQUICC, partnum 0x0000, version C01(0x0031)
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
MC3810 SCB board (v16.B0)
1 Multiflex E1(slot 3) BNC interface(v02.B0)
1 Multiflex E1(slot 4) BNC interface(v02.B0)
1 6-DSP(slot2) Voice Compression Module(v02.C0)
1 6-DSP(slot5) Voice Compression Module(v02.C0)
1 Ethernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
2 Channelized E1/PRI port(s)
256K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (AMD29F016)
LOS_COLORADOS#
6w4d: Bootstrap Emulator called with code 46sh run
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname LOS_COLORADOS
enable secret xxxxx
enable password 7xxxxx
network-clock base-rate 56k
ip subnet-zero
no ip domain-lookup
frame-relay switching
controller E1 0
framing NO-CRC4
tdm-group 1 timeslots 16
controller E1 1
framing NO-CRC4
mode cas
voice-group 0 timeslots 1-15,17-25 type e&m-melcas-immed
process-max-time 200
interface Ethernet0
ip address 130.100.0.100 255.255.0.0
no ip directed-broadcast
interface Serial0
description CANTV-FR-LOS_COLORADOS
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
cdp enable
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0.105 point-to-point
description LOS_GUAYOS-FR-CANTV
ip address 130.101.2.1 255.255.255.0
no ip route-cache
no ip mroute-cache
frame-relay interface-dlci 105
class fr-valencia
vofr cisco
interface Serial0.410 point-to-point
description ENLACE C.C. EL ARBORAL CIR#13325
bandwidth 64
ip address 130.101.39.1 255.255.255.0
no ip route-cache
no ip mroute-cache
frame-relay class vofr
frame-relay interface-dlci 410
vofr cisco
interface Serial1
no ip address
shutdown
interface Switch0
no ip address
no fair-queue
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 130.101.31.2
i.
map-class frame-relay fr-valencia
frame-relay voice bandwidth 24000
frame-relay fragment 80
no frame-relay adaptive-shaping
frame-relay cir 48000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 48000
frame-relay fair-queue
map-class frame-relay fr64cir32
frame-relay cir 32000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 32000
map-class frame-relay fr-64cir
frame-relay cir 64000
frame-relay bc 1000
frame-relay be 0
frame-relay mincir 64000
map-class frame-relay fr-cantv-256
frame-relay fragment 320
frame-relay cir 256000
frame-relay bc 2560
frame-relay be 0
frame-relay mincir 256000
map-class frame-relay vofr
frame-relay bc 1000
frame-relay be 0
line con 0
password xxxx
transport input none
line aux 0
line 2 3
line vty 0 4
password xxxxx
login
voice-port 1/1
timeouts call-disconnect 0
voice-port 1/15
voice-port 1/25
dial-peer voice 6220 vofr
destination-pattern 622.
session target Serial0 145
dial-peer voice 102 pots
preference 1
destination-pattern 1
port 1/2
prefix 1
dial-peer voice 6250 vofr
destination-pattern 625.
session target Serial0 410
dial-peer voice 8030 vofr
destination-pattern 803.
session target Serial0 461
end
LOS_COLORADOS#
-------------------------------------------Router remote locality Cisco 1750
Sh ver , Sh run
ARBORAL-R#sh ver
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 14:29 by ccai
Image text-base: 0x800080DC, data-base: 0x8091BFC0
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ARBORAL-R uptime is 1 day, 30 minutes
System image file is "flash:c1700-sv3y-mz.121-2.T"
cisco 1750 (MPC860) processor (revision 0x601) with 24576K/8192K bytes of memory.
Processor board ID JAD041707L9 (4175675067), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
2 Voice FXS interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
ARBORAL-R#
sh run
version 12.1
hostname ARBORAL-R
enable password xxx
usernamexxxxprivilege 15 password 7xxx
memory-size iomem 25
ip subnet-zero
interface Serial0
no ip address
--More-- ip address 130.101.39.2 255.255.255.0
vofr cisco
interface FastEthernet0
ip address 130.39.39.100 255.255.0.0
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 130.101.39.1
no ip http server
frame-relay bc 1000
frame-relay be 0
voice-port 2/0
voice-port 2/1
dial-peer voice 1 vofr
destination-pattern ....
dial-peer voice 6250 pots
destination-pattern 6250
port 2/0
dial-peer voice 6251 pots
destination-pattern 6251
port 2/1
line con 0
login local
line aux 0
login local
line vty 0 4
password xxxx
login local
end
ARBORAL-R#
ARBORAL-R#
----------------------------------Router remote locality Cisco 1750---------------------
Debug voice ccaip inout
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#
1d00h: cc_api_call_setup_ind (vdbPtr=0x810920C0, callInfo={called=6250,called_oct3=0x0,calling=,calling_oct3=0x0,subscriber_type_str=Unknown,
fdest=1 peer_tag=0},callID=0x80DA2CE0)
1d00h: cc_api_call_setup_ind type 0 , prot 11
1d00h: cc_process_call_setup_ind (event=0x81093FA8) handed call to app "DEFAULT"
1d00h: sess_appl: ev(23=CC_EV_CALL_SETUP_IND), cid(1), disp(0)
1d00h: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1), disp(0)
1d00h: ccCallSetContext (callID=0x1, context=0x81074ED4)
1d00h: ssaCallSetupInd finalDest cllng(), clled(6250)
1d00h: ssaSetupPeer cid(1) peer list: tag(6250) called number (6250) tag(1) called number (6250)
1d00h: ssaSetupPeer rotary_dialpeer_status(1)
1d00h: ssaSetupPeer cid(1), destPat(6250), matched(4), prefix(), peer(81213410), peer->encapType (1)
1d00h: ccCallProceeding (callID=0x1, prog_ind=0x0)
1d00h: ccCallSetupRequest (Inbound call = 0x1, outbound peer =6250, dest=, params=0x81074EE8 mode=0, *callID=0x8109F780)
1d00h: ccCallSetupRequest numbering_type 0x0
1d00h: dest pattern 6250, called 6250, digit_strip 1
1d00h: callingNumber=, calledNumber=6250, redirectNumber=
1d00h: accountNumber=, pinNumber=
1d00h: finalDestFlag=1, guid=06e4.bc49.8945.18d6.0000.0000.ed5e.1dae
1d00h: peer_tag=6250
1d00h: ccIFCallSetupRequestPrivate: (vdbPtr=0x81069AF4, dest=, callParams={called=6250,called_oct3=0x0, calling=,calling_oct3=0x0, subscriber_type_str=Unknown, fdest=1, voice_peer_tag=6250},mode=0x0) vdbPtr type = 6
1d00h: ccIFCallSetupRequestPrivate: (vdbPtr=0x81069AF4, dest=, callParams={called=6250, called_oct3 0x0,
calling=,calling_oct3 0x0,fdest=1, voice_peer_tag=6250}, mode=0x0)
1d00h: ccSaveDialpeerTag (callID=0x1, dialpeer_tag=
1d00h: ccCallSetContext (callID=0x2, context=0x81075640)
1d00h: cc_api_call_proceeding(vdbPtr=0x81069AF4, callID=0x2,
prog_ind=0x0)
1d00h: cc_api_call_alert(vdbPtr=0x81069AF4, callID=0x2, prog_ind=0x8, sig_ind=0x1)
1d00h: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(2), disp(0)
1d00h: cid(2)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
1d00h: -cid2(1)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
1d00h: ssaIgnore cid(2), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
1d00h: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(2), disp(0)
1d00h: cid(2)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
1d00h: ccCallAlert (callID=0x1, prog_ind=0x8, sig_ind=0x1)
1d00h: ccConferenceCreate (confID=0x8109F7F8, callID1=0x1, callID2=0x2, tag=0x0)
1d00h: cc_api_bridge_done (confID=0x1, srcIF=0x810920C0, srcCallID=0x1, dstCallID=0x2, disposition=0, tag=0x0)
1d00h: cc_api_bridge_done (confID=0x1, srcIF=0x81069AF4, srcCallID=0x2, dstCallID=0x1, disposition=0, tag=0x0)
1d00h: cc_api_caps_ind (dstVdbPtr=0x810920C0, dstCallId=0x1, srcCallId=0x2,
caps={codec=0xEBFB, fax_rate=0x7F, vad=0x3, modem=0x2
codec_bytes=0, signal_type=3})
1d00h: cc_api_caps_ind (Playout: mode 0, initial 56068,min 33034, max 5688)
1d00h: cc_api_caps_ind (dstVdbPtr=0x81069AF4, dstCallId=0x2, srcCallId=0x1,
caps={codec=0x8, fax_rate=0x2, vad=0x2, modem=0x1
codec_bytes=30, signal_type=2})
1d00h: cc_api_caps_ind (Playout: mode 0, initial 0,min 0, max 0)
1d00h: cc_api_caps_ack (dstVdbPtr=0x81069AF4, dstCallId=0x2, srcCallId=0x1,
1d00h: cc_api_caps_ack (dstVdbPtr=0x810920C0, dstCallId=0x1, srcCallId=0x2,
1d00h: cc_api_call_disconnected(vdbPtr=0x81069AF4, callID=0x2, cause=0xAC)
1d00h: sess_appl: ev(28=CC_EV_CONF_CREATE_DONE), cid(1), disp(0)
1d00h: cid(1)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_MAPPING)cfid(1)csize(0)in(1)fDest(1)
1d00h: -cid2(2)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
1d00h: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(2), disp(0)
1d00h: cid(2)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CALL_SETTING)cfid(1)csize(0)in(0)fDest(0)
1d00h: -cid2(1)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_ALERT)
1d00h: ssaDisconnectedAlert: redirect_numbers(0)
1d00h: ccConferenceDestroy (confID=0x1, tag=0x0)
1d00h: cc_api_bridge_drop_done (confID=0x1, srcIF=0x810920C0, srcCallID=0x1, dstCallID=0x2, disposition=0 tag=0x0)
1d00h: cc_api_bridge_drop_done (confID=0x1, srcIF=0x81069AF4, srcCallID=0x2, dstCallID=0x1, disposition=0 tag=0x0)
1d00h: sess_appl: ev(29=CC_EV_CONF_DESTROY_DONE), cid(1), disp(0)
1d00h: cid(1)st(SSA_CS_ALERT_DISC_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(1)csize(0)in(1)fDest(1)
1d00h: -cid2(2)st2(SSA_CS_ALERT_DISC_CONF_DESTROYING)oldst2(SSA_CS_CONFERENCED_ALERT)
1d00h: ssa: Disconnected cid(2) state(11) cause(0xAC)
1d00h: ssaCallDisconnectAlert: cid(2), peer-cid(1)
1d00h: ccCallDisconnect (callID=0x2, cause=0xAC tag=0x0)
1d00h: cc_api_call_disconnect_done(vdbPtr=0x81069AF4, callID=0x2, disp=0, tag=0x0)
1d00h: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(2), disp(0)
1d00h: cid(2)st(SSA_CS_ALERT_DISC_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(-1)csize(0)in(0)fDest(0)
1d00h: -cid2(1)st2(SSA_CS_ALERT_DISC_DISCONNECTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
1d00h: ssaDisconnectDone: Rotary Retry cid(1) peer list: tag(1) called number (6250)
1d00h: ssaSetupPeer cid(1) peer list: tag(1) called number (6250)
1d00h: ssaSetupPeer rotary_dialpeer_status(2)
1d00h: ssaSetupPeer cid(1), destPat(6250), matched(0), prefix(), peer(81211DC4), peer->encapType (5)
1d00h: ccCallSetupRequest (Inbound call = 0x1, outbound peer =1, dest=, params=0x81074EE8 mode=0, *callID=0x8109F7C0)
1d00h: dest pattern ...., called 6250, digit_strip 0
1d00h: peer_tag=1
1d00h: ccIFCallSetupRequestPrivate: (vdbPtr=0x810920C0, dest=, callParams={called=6250,called_oct3=0x0, calling=,calling_oct3=0x0, subscriber_type_str=Unknown, fdest=1, voice_peer_tag=1},mode=0x0) vdbPtr type = 11
1d00h: ccCallSetContext (callID=0x3, context=0x810C0998)
1d00h: cc_api_call_proceeding(vdbPtr=0x810920C0, callID=0x3,
prog_ind=0x8)
1d00h: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(3), disp(0)
1d00h: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
1d00h: -cid2(1)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
1d00h: ssaIgnore cid(3), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
1d00h: cc_api_call_disconnected(vdbPtr=0x810920C0, callID=0x3, cause=0x3)
1d00h: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(3), disp(0)
1d00h: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_DISCONNECTED)
1d00h: ssa: Disconnected cid(3) state(1) cause(0x3)
1d00h: ccCallDisconnect (callID=0x3, cause=0x3 tag=0x0)
1d00h: ccCallDisconnect (callID=0x1, cause=0x3 tag=0x0)
1d00h: cc_api_call_disconnect_done(vdbPtr=0x810920C0, callID=0x3, disp=0, tag=0x0)
1d00h: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(3), disp(0)
1d00h: cid(3)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
1d00h: -cid2(1)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
1d00h: cc_api_call_disconnect_done(vdbPtr=0x810920C0, callID=0x1, disp=0, tag=0x0)
1d00h: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(1), disp(0)
1d00h: cid(1)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_ALERT_DISC_CONF_DESTROYING)cfid(-1)csize(1)in(1)fDest(1)
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#
Silver
Since you do not have header compression turned on can you increase the frame relay voice bandwidth from 24000 to 32000, it may be that the call is overshooting that bandwidth and in vofr the call will not go through. Also if you could include millisecond debugging
service timestamps debug d msec
and also include debug cch323 session and debug h225 asn. That would be great.
Hi ...
The comand for compresion is ???
frame relay ip tcp header-compresion ......
in the network I am not using H323 for the control of the voice
down is the asked for information ...
---------------Debug voice ccaip inout-----------------------------------
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#ter moni
ARBORAL-R#
*Mar 4 00:01:59.358: cc_api_call_setup_ind (vdbPtr=0x810920C0, callInfo={called=6250,called_oct3=0x0,calling=,calling_oct3=0x0,subscriber_type_str=Unknown,
fdest=1 peer_tag=0},callID=0x80FF6BB4)
*Mar 4 00:01:59.358: cc_api_call_setup_ind type 0 , prot 11
*Mar 4 00:01:59.362: cc_process_call_setup_ind (event=0x81093FA8) handed call to app "DEFAULT"
*Mar 4 00:01:59.362: sess_appl: ev(23=CC_EV_CALL_SETUP_IND), cid(1), disp(0)
*Mar 4 00:01:59.362: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(1), disp(0)
*Mar 4 00:01:59.362: ccCallSetContext (callID=0x1, context=0x81074A5C)
*Mar 4 00:01:59.366: ssaCallSetupInd finalDest cllng(), clled(6250)
*Mar 4 00:01:59.366: ssaSetupPeer cid(1) peer list: tag(6250) called number (6250) tag(1) called number (6250)
*Mar 4 00:01:59.366: ssaSetupPeer rotary_dialpeer_status(1)
*Mar 4 00:01:59.366: ssaSetupPeer cid(1), destPat(6250), matched(4), prefix(), peer(81213410), peer->encapType (1)
*Mar 4 00:01:59.366: ccCallProceeding (callID=0x1, prog_ind=0x0)
*Mar 4 00:01:59.366: ccCallSetupRequest (Inbound call = 0x1, outbound peer =6250, dest=, params=0x81074A70 mode=0, *callID=0x8109F780)
*Mar 4 00:01:59.366: ccCallSetupRequest numbering_type 0x0
*Mar 4 00:01:59.366: dest pattern 6250, called 6250, digit_strip 1
*Mar 4 00:01:59.370: callingNumber=, calledNumber=6250, redirectNumber=
*Mar 4 00:01:59.370: accountNumber=, pinNumber=
*Mar 4 00:01:59.370: finalDestFlag=1, guid=06e4.bc49.8945.19b9.0000.0000.fdc3.ac59
*Mar 4 00:01:59.370: peer_tag=6250
*Mar 4 00:01:59.370: ccIFCallSetupRequestPrivate: (vdbPtr=0x81069AF4, dest=, callParams={called=6250,called_oct3=0x0, calling=,calling_oct3=0x0, subscriber_type_str=Unknown, fdest=1, voice_peer_tag=6250},mode=0x0) vdbPtr type = 6
*Mar 4 00:01:59.370: ccIFCallSetupRequestPrivate: (vdbPtr=0x81069AF4, dest=, callParams={called=6250, called_oct3 0x0,
*Mar 4 00:01:59.370: ccSaveDialpeerTag (callID=0x1, dialpeer_tag=
*Mar 4 00:01:59.370: ccCallSetContext (callID=0x2, context=0x810C043C)
*Mar 4 00:01:59.378: cc_api_call_proceeding(vdbPtr=0x81069AF4, callID=0x2,
prog_ind=0x0)
*Mar 4 00:01:59.378: cc_api_call_alert(vdbPtr=0x81069AF4, callID=0x2, prog_ind=0x8, sig_ind=0x1)
*Mar 4 00:01:59.378: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(2), disp(0)
*Mar 4 00:01:59.378: cid(2)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
*Mar 4 00:01:59.382: -cid2(1)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
*Mar 4 00:01:59.382: ssaIgnore cid(2), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
*Mar 4 00:01:59.382: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(2), disp(0)
*Mar 4 00:01:59.382: cid(2)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
*Mar 4 00:01:59.382: ccCallAlert (callID=0x1, prog_ind=0x8, sig_ind=0x1)
*Mar 4 00:01:59.382: ccConferenceCreate (confID=0x8109F7F8, callID1=0x1, callID2=0x2, tag=0x0)
*Mar 4 00:01:59.382: cc_api_bridge_done (confID=0x1, srcIF=0x810920C0, srcCallID=0x1, dstCallID=0x2, disposition=0, tag=0x0)
*Mar 4 00:01:59.386: cc_api_bridge_done (confID=0x1, srcIF=0x81069AF4, srcCallID=0x2, dstCallID=0x1, disposition=0, tag=0x0)
*Mar 4 00:01:59.386: cc_api_caps_ind (dstVdbPtr=0x810920C0, dstCallId=0x1, srcCallId=0x2,
*Mar 4 00:01:59.386: cc_api_caps_ind (Playout: mode 0, initial 56068,min 33034, max 5688)
*Mar 4 00:01:59.386: cc_api_caps_ind (dstVdbPtr=0x81069AF4, dstCallId=0x2, srcCallId=0x1,
*Mar 4 00:01:59.386: cc_api_caps_ind (Playout: mode 0, initial 0,min 0, max 0)
*Mar 4 00:01:59.386: cc_api_caps_ack (dstVdbPtr=0x81069AF4, dstCallId=0x2, srcCallId=0x1,
*Mar 4 00:01:59.386: cc_api_caps_ack (dstVdbPtr=0x810920C0, dstCallId=0x1, srcCallId=0x2,
*Mar 4 00:01:59.390: cc_api_call_disconnected(vdbPtr=0x81069AF4, callID=0x2, cause=0xAC)
*Mar 4 00:01:59.390: sess_appl: ev(28=CC_EV_CONF_CREATE_DONE), cid(1), disp(0)
*Mar 4 00:01:59.390: cid(1)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
*Mar 4 00:01:59.390: -cid2(2)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
*Mar 4 00:01:59.390: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(2), disp(0)
*Mar 4 00:01:59.394: cid(2)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_DISCONNECTED)
*Mar 4 00:01:59.394: -cid2(1)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCING_ALERT)
*Mar 4 00:01:59.394: ssaDisconnectedAlert: redirect_numbers(0)
*Mar 4 00:01:59.394: ccConferenceDestroy (confID=0x1, tag=0x0)
*Mar 4 00:01:59.394: cc_api_bridge_drop_done (confID=0x1, srcIF=0x810920C0, srcCallID=0x1, dstCallID=0x2, disposition=0 tag=0x0)
*Mar 4 00:01:59.394: cc_api_bridge_drop_done (confID=0x1, srcIF=0x81069AF4, srcCallID=0x2, dstCallID=0x1, disposition=0 tag=0x0)
*Mar 4 00:01:59.394: sess_appl: ev(29=CC_EV_CONF_DESTROY_DONE), cid(1), disp(0)
*Mar 4 00:01:59.394: cid(1)st(SSA_CS_ALERT_DISC_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
*Mar 4 00:01:59.398: -cid2(2)st2(SSA_CS_ALERT_DISC_CONF_DESTROYING)oldst2(SSA_CS_CONFERENCED_ALERT)
*Mar 4 00:01:59.398: ssa: Disconnected cid(2) state(11) cause(0xAC)
*Mar 4 00:01:59.398: ssaCallDisconnectAlert: cid(2), peer-cid(1)
*Mar 4 00:01:59.398: ccCallDisconnect (callID=0x2, cause=0xAC tag=0x0)
*Mar 4 00:01:59.402: cc_api_call_disconnect_done(vdbPtr=0x81069AF4, callID=0x2, disp=0, tag=0x0)
*Mar 4 00:01:59.402: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(2), disp(0)
*Mar 4 00:01:59.402: cid(2)st(SSA_CS_ALERT_DISC_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
*Mar 4 00:01:59.402: -cid2(1)st2(SSA_CS_ALERT_DISC_DISCONNECTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
*Mar 4 00:01:59.406: ssaDisconnectDone: Rotary Retry cid(1) peer list: tag(1) called number (6250)
*Mar 4 00:01:59.406: ssaSetupPeer cid(1) peer list: tag(1) called number (6250)
*Mar 4 00:01:59.406: ssaSetupPeer rotary_dialpeer_status(2)
*Mar 4 00:01:59.406: ssaSetupPeer cid(1), destPat(6250), matched(0), prefix(), peer(81211DC4), peer->encapType (5)
*Mar 4 00:01:59.406: ccCallProceeding (callID=0x1, prog_ind=0x0)
*Mar 4 00:01:59.406: ccCallSetupRequest (Inbound call = 0x1, outbound peer =1, dest=, params=0x81074A70 mode=0, *callID=0x8109F7C0)
*Mar 4 00:01:59.406: ccCallSetupRequest numbering_type 0x0
*Mar 4 00:01:59.406: dest pattern ...., called 6250, digit_strip 0
*Mar 4 00:01:59.406: callingNumber=, calledNumber=6250, redirectNumber=
*Mar 4 00:01:59.406: accountNumber=, pinNumber=
*Mar 4 00:01:59.410: finalDestFlag=1, guid=06e4.bc49.8945.19b9.0000.0000.fdc3.ac59
*Mar 4 00:01:59.410: peer_tag=1
*Mar 4 00:01:59.410: ccIFCallSetupRequestPrivate: (vdbPtr=0x810920C0, dest=, callParams={called=6250,called_oct3=0x0, calling=,calling_oct3=0x0, subscriber_type_str=Unknown, fdest=1, voice_peer_tag=1},mode=0x0) vdbPtr type = 11
*Mar 4 00:01:59.410: ccSaveDialpeerTag (callID=0x1, dialpeer_tag=
*Mar 4 00:01:59.410: ccCallSetContext (callID=0x3, context=0x810C0D90)
*Mar 4 00:01:59.458: cc_api_call_proceeding(vdbPtr=0x810920C0, callID=0x3,
prog_ind=0x8)
*Mar 4 00:01:59.462: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(3), disp(0)
*Mar 4 00:01:59.462: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
*Mar 4 00:01:59.462: -cid2(1)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
*Mar 4 00:01:59.462: ssaIgnore cid(3), st(SSA_CS_CALL_SETTING),oldst(1), ev(20)
*Mar 4 00:01:59.466: cc_api_call_disconnected(vdbPtr=0x810920C0, callID=0x3, cause=0x3)
*Mar 4 00:01:59.466: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(3), disp(0)
*Mar 4 00:01:59.466: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_DISCONNECTED)
*Mar 4 00:01:59.466: -cid2(1)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_ALERT_DISC_CONF_DESTROYING)
*Mar 4 00:01:59.466: ssa: Disconnected cid(3) state(1) cause(0x3)
*Mar 4 00:01:59.470: ccCallDisconnect (callID=0x3, cause=0x3 tag=0x0)
*Mar 4 00:01:59.470: ccCallDisconnect (callID=0x1, cause=0x3 tag=0x0)
*Mar 4 00:01:59.470: cc_api_call_disconnect_done(vdbPtr=0x810920C0, callID=0x3, disp=0, tag=0x0)
*Mar 4 00:01:59.470: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(3), disp(0)
*Mar 4 00:01:59.474: cid(3)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
ARBORAL-R#
ARBORAL-R#
ARBORAL-R#
139
