Community Member
Problem with VTA and MCU
VTA 2.0.2
CCM 4.1(3)sr3c
MCU3515-12 with 5.0.58 running in SSCP mode.
All works as expected upto 3 parties in both ad-hoc and meetme.
When 4 parties involved works fine with meetme, but not with ad-hoc. The person initiating the conference only sees 2 parties, others see the other 3 ok (but only when enabled "no self see"). When "no self see" is disabled, initiating party still only sees 2 others, and the others get a black screen.
The CCM meetme & ad-hoc max number is set to 6.
All parties are in the same location/region so no B/W issues. All running G711.
Anyone seen similar problems?
Many thanks.
Bronze
Re: Problem with VTA and MCU
The issue is that it can hold only upto two neighboring parties and to resolve the issue it can be upgraded to other version where it can hold upto more than two parties.
Community Member
Can you explain further. Do you mean upgrade the MCU code? It seems to be on the latest already. The same goes for the VTA code.
Thanks.
Community Member
I am running the same configuration with the same issues. Did we come up with a resolution?
Community Member
Unfortunately no resolution as yet. I was kind of hoping Gabriel would explain further what he meant.
Community Member
I had the same issue, but when I changed MCU software to 5.0.1.0.12 (MCU) and 5.0.1.0.6 (EMP) problem is resolved.
Wojtek
135
