qos for avaya ip phones
Has anyone configured qos on cisco switches for avaya phones?
Is it the same as configuring for Cisco phones or are there differences?
Rob
1 REPLY
Bronze
Re: qos for avaya ip phones
pretty much the same. All avaya ip endpoints and gateways can be configured with whatever cos/diffserv values and RTP UDP port range you need.This is done via the ip-network-region screen on the avaya system. Here's a great docuement:
http://support.avaya.com/elmodocs2/comm_mgr/r3/pdfs/245600_3_4_1.pdf
Also, you can also still use the "voice" vlan command instead of doing an explicit dot1q trunk to the avaya phone:
interface FastEthernet0/2
Description to IP phone and PC
switchport mode access
switchport access vlan 10
switchport voice vlan 11
mls qos trust cos
spanning-tree portfast
change the avaya network regions to conform with the the following cisco network recommendations.
COS DSCP Usage
3 24 Signaling
5 46 Bearer
Also autoqos works well as long as the above is configured on avaya equipment here is another document going over autoqos..a bit old but still good
http://www1.avaya.com/enterprise/applicationnotes/autoqos.pdf
576
