Questions about VoIP, Can anybody help me?
Hi All,
I am learning VoIP now and I have serveral questions:
1. when I use "destination-pattern" command in "dial-peer" command, how will the number forwarded? For example: If I want to forward the number 123456 to ip x.x.x.x. If I use "destination-pattern 12...." to identify the number, the router will forward 123456 to x.x.x.x or 3456 to x.x.x.x? I think the answer is 123456. Am I right? And If I am right, there is another issue. What should I do if I just want to forward 3456 when received 123456? I think this is helpful to implement the dialing plan to use some digits as a prefix and discard the prefix to forward to another destination when received the number.
2. Can cisco router only support e.164 numbering plan? Can I use another? How can I explicity config the numbering plan in the router?
3. If there is a case like this:
PhoneA--R1--R2--R3--R4--PhoneB
R2 and R3 is connected via frame-relay. So when I use the "dial-peer" command in R1 and R4, should I use "voip" or "vofr" parameter?
Thank You!
Best Regards
Teru Lei
1 REPLY
Re: Questions about VoIP, Can anybody help me?
1) Here is an example of a dial-peer
Dial-peer voice 123456 voip #this mean this is a voip type dial peer name #123456
destination-pattern 123456T # mean when you will call 123456 and any number after that it will go to this dial peer
session target ipv4:192.168.0.1 # this will fwd the packet to that IP when you #will call 123456......
If you like to call somthing and send somthing else you can do translation rule
translation-rule 1
Rule 1 123456 3456
and on the dial-peer you need to set
translate-outgoing calling 1
2) Yes it support E.164
3) I would reccomand to use VOIP
145
