Community Member
Re: CME and Analog Phones
I have CME running on a Cisco 2801 router and I have installed a 4FXS card. I have an analog phone connected to the port 0/2/0 of the FXS card and the following is configured.
dial-peer voice 201 pots
destination-pattern 4015
port 0/2/0
I am able to initiate calls from this unit however calls to this DN (analog) phone I receive a fast busy.
Also how do I transfer a call from an analog phone in this setup?
Re: Re: CME and Analog Phones
Hi, I had exactly the same issue ... The attached is a partial configuration that incorporates two POTS lines into a hunt group (800), with CLI services, Unity VM AIM and MWI. The Analog phone is on extension 402. Think you need to look at enabling the service "stcapp" to get your config working
Hope it helps
Jason
Community Member
Thanks, I tried this config and I am still experincing the same problem. Also I can enable service service stcapp, what is it used for?
Hall of Fame Super Gold
This is the feature explained:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html
After the basic is working, you can configure a fac to access various functions:
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_6xe/htfeatmd.html
242
