Community Member
SIP Gateway - Voice quality
Hello All,
I have a media server which runs IVR connected to Voice gateway. Media server runs on SIP and cisco 2811 is configured as SIP gateway. Gateway Connects to E1 pri for DID. I have a problem with voice quality. When we call,gateway redirects to media server and IVR starts but with voice cuts. So is the problem with gateway config or Media server.?
The other problem is medai server can call outside and gateway is configured to do so. But when we pick up the call, it disconnects.
GatewayConfiguration:
Dial-peer voice 1 pots
description Incoming calls from PSTN
Incoming called-number .T
Direct-inward-dial
Port 0/0/1:15
dial-peer voice 2 voip
description Incoming calls to server
destination-pattern 448447.
session protocol sipv2
session target ipv4:{Media Server IP}
incoming called-number 448447.
dtmf-relay rtp-nte
codec g711alaw
Dial-peer voice 3 pots
description Outgoing
destination-pattern 0[7-8]0........
Port 0/0/1:15
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
signaling forward unconditional
fax protocol cisco
h323
sip
interface FastEthernet0/1
description $WAN INTERFACE$
ip address
ip nat outside
ip virtual-reassembly
no ip mroute-cache
duplex auto
speed auto
interface Serial0/0/0:15
no ip address a.b.c.d
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
no cdp enable
Re: SIP Gateway - Voice quality
Try a few things:
network-clock-select 1 e1 0/0/0
And:
incoming called-number .
hth,
nick
Community Member
Thanks Nick.
But still same.No improvements.
Hall of Fame Super Gold
Try no vad under DP, check out LAN between GW and IVR.
222
