SIP to SIP Call Failures on CME to CME - sip-ua conflict/issue?
I have two existing CME systems which I wish to allow internal calls between. These calls will go over an IPSec VPN. However the calls are failing.
Phones DN22xx - London CME 2801 - PIX505 --- Internet ---ASA5505 - India CME 2801 - Phones DN400x
I have configured dial peers on both CME's and the IPSec VPN. I can ping between both systems. The VPN allows traffic between the interface IP's of the CME systems only.
London CME (local SCCP phones 22xx):
interface FastEthernet0/0.100
encapsulation dot1Q 100 native
ip address 10.0.10.250 255.255.255.0
voice class codec 101
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
dial-peer voice 25 voip
description *** SIP Peer to India ***
answer-address 400.
destination-pattern 400.
voice-class codec 101
session protocol sipv2
session target ipv4:192.168.15.10
incoming called-number 400.
no vad
India CME (Local SSCP phones 400x):
ip address 192.168.15.10 255.255.255.0
voice class codec 100
dial-peer voice 10 voip
description *** SIP Peer to London UK ***
answer-address 22..
destination-pattern 22..
voice-class codec 100
session target ipv4:10.0.10.250
incoming called-number 22..
no vad
The CME system at India also has an existing SIP dial peer to a service provider and has sip-ua configured (username, password, realm and registrar).
A call from India (4005) to London (DN2207) fails, the ccsip debug attached. I'm assuming its because the sip-ua configuration is being used for these calls to when I don't want it to be. The from field shows “From: <sip:4005@201.196.128.56” when I need this to be the internal IP 192.168.15.10.
Can anyone offer any assistance with this?
Chris
Re: SIP to SIP Call Failures on CME to CME - sip-ua conflict/iss
Can you bind the SIP to the proper interface on both India and London CME.
Looks like there is no bind for media and signalling and so its using the source address of the outbound interface, which is 201.196.128.56
thanks for your input however thats not the problem. 201.196.128.56 isn't an address on the router, it only has one IP and its 192.168.15.10.
The 201.196.128.56 address is the NAT'd address on the firewall. So that when a SIP call is made to the internet with sip-ua the from address is the public IP.
Chris
210
