Troubleshooting with ip communicator and VT advantage
aherraez77
Hello:
I have a Ip communicator version 2.0.1 and a CME 4.3. In theory I should see the camera icon in the screen of the IP communicator but I don't see it.
I have another problem wiht the VT advantage. It don't see the IP communicator. I don't know if the cause is the first problem o it is another problem.
I have configured in Telephone-service: service phone videoCapability 1
video
maximum bit-rate 384
and in the phone I have the video command.
What can I see or do for the two problems?
Thanks everybody
antonio
5 Replies 5
david-lima
Level 4
Level 4
Hi Antonio, please verify under Telephony-services:
telephony-service
service phone videoCapability 0
video
maximum bit-rate value
And reset the phones where the video command is applied.
All the best
David
Best regards
David
Hello:
I have that commands. But it is 0 or 1?. I have read that 1 is for enable it and 0 for disable.
the phones have been reseted too. Now I have the Ip communicator 7 and the result is the same: the camera icon doesn't appears
regards
Hi again, try disabling service phone videoCapability and enable it again, then apply the command create cnf-files and reset the phones.
All the best
David.
Hello:
It does't work, but I have used the command type CIPC and all goes fine. Now I have the camera icon and video.
Thanks for all
antonio
