Upgrade Problems IPVC GW and MCU
I am upgrading the MCU from Vers. 2.2 and the GWY module from Vers 1.1 to 3.2Plus at least, however both have failed.
On the MCU, we upgraded one step at a time, we were successful to 2.7, however failed when upgrading to 3.2. It seems we ran out of flashmem.
On the GWY, the upgrade utility will not take the proper username and password for some reason.
If anyone has experienced this before, please respond with some sort of advice.
Silver
Re: Upgrade Problems IPVC GW and MCU
try selecting 'Customize' button,then select all options including the default configuration and run the upgrade to 3.2
We simply did not have enough flashmem. Apparently on the older IPVC MCU's, they came with a smaller amount of flashmem then the MCU's running 3.x. Now I believe this is only on the original 1st Generation IPVC's and after Cisco had been using the Radvision platform for a bit, they upgraded the flashmem level.
119
