URGENT: NEC LCD display with Telepresence 1000
kurtdeneef
Urgent question,is it possible to attach the LCD screen (manufacturer: NEC) to the Telepresence system or do you simply have to attach it onto the wall next to it?
Kurt
irisrios
Level 6
Level 6
Telepresence-1000 are using a data display either mounted or desk supported. This should be connected with a HDMI to DVI cable. The input would use a VGA to DVI cable.
http://www.cisco.com/en/US/docs/solutions/TelePresence_Network_Systems_1.1_DG.pdf
irisrios
Level 6
Level 6
