Hi!
I need a solution to use the PAI or the RemoteParty from SIP to ISDN. The only things i have fount is from PSTN to SIP to set a fixed PAI (Official Cisco IOS SIP Config Guide for 12.4T)
Example of Call-Routing:
Softphone with username dials pstn-number -> SIP-Server sets everything and sends invite so cisco-gw --> Cisco AS5350XM receives call, matches dial-peers and send to PSTN --> 2xE1 to PSTN in a trunk-group (DMS Public Switch)
In the trunk-group i've assigned translation-rules to change ISDN type and add 00 to prefix
In the INVITE Message i have the following numbers assigned.
P-Asserted-Identity: <sip:00431NNNNNNNNNNN>
Remote-Party-ID: <sip:00431NNNNNNNNNNN>
My problem is that instead of the PAI or the Remote-Party-ID, the SIP-URI of the FROM get used in the ISDN SETUP Message:
Calling Party Number i = 0x0180, 'username'
I've configured remote-party-id in the sip-ua config-mode but when i make show run it doesn't get displayed.
I use the following IOS version at the moment in my test environment:
Cisco IOS Software, 5350 Software (C5350-JK9S-M), Version 12.4(24)
For this problem i couldn't found a solution on cisco pages, cisco books nor any website. So i hope someone could help me here. Thanks
BR,
Christoph H.
