Verizon IP Trunk and CME/CUE, call transfers failing
Anyone experiencing the issue using a SIP trunk and CM cannot transfer calls when initiated on the trunk. There is no issue when the call is initated on a analog line connected to an FXO port.
Hall of Fame Super Gold
Re: Verizon IP Trunk and CME/CUE, call transfers failing
CM or CME? If the latter which version?
If recent enough, you need to cofigure
voice service voip
no supplementary-service sip moved-temporarily
And CME will stop trying to do SIP-based transfers.
Was there a resolution to this one?
For CME, the commands I've mentioned above.
670
