Video Management and Storage Solutions installation problem
I've been struggling to get the VMSS software installed on a SM-SRE-700-K9 that is in a 2911 router for quite some time now. TAC is trying to help me but it's taking way too long.
Here is what I have so far...
Every time I start a session with the service module it goes straight into the "ServicesEngine boot-loader>" prompt. When I try to do a boot helper command it appears to go through trying to install the software but doesn't go through. See below:
ServicesEngine boot-loader> boot helper
Loading tftp://192.168.1.30/vmss-boothelper.sme.6.2.2 ... done.
Verifying ... done.
Starting Kernel.
Platform: sm
INIT: version 2.86 booting
mounting proc fs ...
mounting sys fs ...
mounting /dev/shm tmpfs ...
kernel.sem = 1900 4000 32 100
vm.overcommit_memory = 1
                Welcome to Cisco Service Engine
Setting the system time from hardware clock
********** rc.aesop ****************
Populating resource values from /etc/sm_rsrc_file
Populating resource values from /etc/default_rsrc_file
Populating resource values from /etc/products/argus/sm_rsrc_file
==> Management interface is eth0
IOS IP Address Registration complete.
Kernel IP routing table
Destination     Gateway         Genmask         Flags   MSS Window  irtt Iface
172.30.10.128   *               255.255.255.192 U         0 0          0 eth0
default         172.30.10.129   0.0.0.0         UG        0 0          0 eth0
Size of buff is: 65536
65536 bytes written
Valid License file not found: Using default values
INIT: Entering runlevel: 2
********** rc.post_install ****************
Changing owners and file permissions.
Change owners and permissions complete.
INIT: Switching to runlevel: 4
INIT: Sending processes the TERM signal
STARTED: dwnldr_startup.sh
sre_type=  0
        Welcome to Cisco Systems Service Engine Helper Software
Please select from the following
1       Install software
2       Reload module
3       Disk cleanup
4       Install License(s)
(Type '?' at any time for help)
Choice: 1
Package name: vmss-k9.sme.6.2.2.pkg
Server url: ftp://192.168.1.30
Username: admin
Password:
Downloading ftp vmss-k9.sme.6.2.2.pkg
Bytes downloaded :  680201
Validating package signature ... done
- Parsing package manifest files... complete.
No installed manifests found.
- Checking Package dependencies... complete.
- Checking Manifest dependencies for subsystems in the install candidate list...
complete
Populating resource values from /etc/products/argus/noraid_rsrc_file
WARNING:: Software installation will clear disk contents
Continue (y/n) [n]? y
Command (m for help): Partition number (1-4):
Command (m for help): Selected partition 1
Command (m for help): Command action
   e   extended
   p   primary partition (1-4)
Partition number (1-4): First cylinder (1-1011, default 1): Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-1011, default 1011): Value out of range.
Last cylinder or +size or +sizeM or +sizeK (1-1011, default 1011): Last cylinder or +size or +sizeM or +sizeK (1-1011, default 1011):
   e   extended
Partition number (1-4): First cylinder (84-1011, default 84): Using default value 84
Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Value out of range.
Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Value out of range.
Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Value out of range.
Last cylinder or +size or +sizeM or +sizeK (84-1011, default 1011): Using default value 1011
Command (m for help): Command (m for help): Command (m for help): Partition number (1-4): Partition 3 does not exist yet!
Command (m for help): 8: unknown command
Command action
   a   toggle a bootable flag
   b   edit bsd disklabel
   c   toggle the dos compatibility flag
   d   delete a partition
   l   list known partition types
   m   print this menu
   n   add a new partition
   o   create a new empty DOS partition table
   p   print the partition table
   q   quit without saving changes
   s   create a new empty Sun disklabel
   t   change a partition's system id
   u   change display/entry units
   v   verify the partition table
   w   write table to disk and exit
   x   extra functionality (experts only)
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
Syncing disks.
mkreiserfs 3.6.19 (2003 www.namesys.com)
Setting up swapspace version 1, size = 1885335 kB
no label, UUID=3b1bd066-54cf-4b09-9c2f-e1d970a0a133
mke2fs 1.41.0 (10-Jul-2008)
mke2fs: No such device or address while trying to determine filesystem size
mount: you must specify the filesystem type
Could not mount /dev/sda3 at /mnt
mounting /dev/sda1
Not enough disk space to download necessary files.
Error encountered while downloading payload(s)
Unable to install. Please try again
Then when TAC asked to install without being in the SM I get the following errors:
N3L010RT#$install url ftp://admin:cisco@192.168.1.30/vmss-k9.sme.6.2.2.pkg
Proceed with installation? [no]: y
Loading vmss-k9.sme.6.2.2.pkg.install.sre !
[OK - 7918/4096 bytes]
If you are installing on a system which already has VMSS installed your media partition may contain archives.
Would you like for the install to preserve this partition if it exists? Please note that if you are changing
your RAID option from the previous install, the media partition will not be preserved.  Preserve? [n]: n
N3L010RT#serv
N3L010RT#service-module sm1/0 status
Service Module is Cisco SM1/0
Service Module supports session via TTY line 67
Service Module is trying to recover from error
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
  CPU Frequency: 1865 MHz
  Memory Size: 2530 MB
  Disk 0 Size: 500107 MB
  Disk 1 Size: 2055 MB
Install of ftp://*****:*****@192.168.1.30/vmss-k9.sme.6.2.2.pkg in progress
Install status : Waiting for RBIP registration
Local Partition Info - (0 apps)
  Retrieving partition information
Install status : File vmss-k9.sme.6.2.2.pkg.install.sre requested
Service Module is in Steady state
Getting status from the Service Module, please wait..
SM1/0 is reset due to Error encountered while downloading payload(s) .Service Module status is not available
No install/uninstall in progress
Can someone point me in the right direction? I would greatly appreciate it!
  • Video Over IP
Everyone's tags (2)
583
