voice Network module not recognised
Can someone tell me if this is a hardware failure. There is two vic-2FXS connected to the NM-2V. It has been working but after a power trip yesterday, all my voip configuration is now missing.
sh diag
Slot 1:
Unknown (type 101) Port adapter <<<<<
Port adapter is disabled
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision C0
Serial number 30601430 Part number 800-02491-04
FRU Part Number: NM-2V=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x00: 01 65 01 01 01 D2 F0 D6 50 09 BB 04 00 00 00 00
0x10: 60 00 00 00 03 08 08 17 FF FF FF FF FF FF FF FF
Tried connecting a analog phone to the FXS port and there is no dial-tone. Is this a hardware issue? if it is, which part should a RMA be issued?
Re: voice Network module not recognised
can you post the show version o/p here ?
also can you switch ur router off and try taking out and reinserting the card ?
wht does the LED indication tells in that card ??
do u have any spare router to check this FXS module ??
regd
Oh.. i got it sorted out...
There was a power failure and the IOS reverted to the older version and that version of IOS doesn't support that card.
I need to revert it back to the new IOS and now the problem is now solved.
135
