Community Member
VoIP publisher/subscriber issue
We currently only have all our VoIP phones going to the Publisher because we are unable to get the Pub and Sub to talk to each other.  We are trying to get our one Sub we have up to work and then stand up 2 more.  I am just wondering what all can cause this issue or if anyone has had simliar troubles?
Everyone's tags (2)
Start by checking the replication, also try a cluster reboot.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
It is not replicating.
Re: VoIP publisher/subscriber issue
Is the sub added on the pub with the correct admin and security password?
What version of cucm do u run?
Voice CCIE #37771
Community Member
Verified the password is correct and we run ver. 8.6.1.20009-3
So from cli via ssh you can login and ping each other?
Screenshot of your cluster setup please
Voice CCIE #37771
310
