Silver
VT Advantage 2.0(1)a and H.323 endpoints
Has anyone observed any interoperability issues with CVTA 2.0(1)a and H.323 endpoints; specifically Polycom ViaVideo endpoints? After upgrading to CVTA 2.0 the remote video quality is poor with occasional coloured blocks around areas of movement. The problem is not observed with CVTA 1.0(2).
The video calls are directly between endpoints; the is no intervening IP-IP gateway, though the H.323 endpoints are registered to a gatekeeper and a GK-controlled trunk is configured between CCM and the GK.
1 REPLY
Community Member
Re: VT Advantage 2.0(1)a and H.323 endpoints
I did observe a similar behaviour. Having the same setup with CCM4.1(3), CVTA 2.0 or 7985 phones, the connection is audio only until I put the call on a CallManager device on hold an resume it. Then it works fine.
Does someone know how to avoid this?
Cheers
Roland
153
