06-08-2006 03:48 AM - edited 03-17-2019 08:43 PM
Has anyone experienced problems with the microphone installed in the VT Advantage USB Camera when using it IP communicator.
The Microphone seems to funtion correctly if used by other applications like skype and messenger.
Miron du Plessis
06-14-2006 05:29 AM
you need the latest version (1.1(1) of communicator. You must run the installer, and not AutoUpdate to this version
06-14-2006 12:42 PM
Yes, I have the same problem. It worked once then I ran the audio tuning and the mic no longer functions. Works fine with other apps.
IP Communicator 2.0.1.1
VT Avantage 2.0.1.1
07-18-2006 08:53 AM
I have simular problem
VT Avantage 2.0.1.1
I select audio tuning wizard on the communicator and see that the communicator has the SoundMAX digital Audio selected... that works on my computer with the onboard mic, but if I want to use the mic on the Camera it self, I cant find the option to choose it, it is not visible in the dropdown list in the Tunning wizard.
02-14-2007 12:07 PM
Anyone find a resolution to this?
IPC 2.0.2.0
UVA 2.0.2.0
I don't see the VTA mic in the audio tuning wizard either.
02-21-2007 04:01 AM
Maybe, the resolution is to change the default recording device in Windows Control Panel
control panel>Sounds and Audio Devices>Voice> Voice recording>Default device
I don't use VT advantage, is the microphone VTA visible in control panel? Did you try this to do?
02-21-2007 01:14 PM
Yes, even though the VT camera is the default device in control panel, IP Communicator does not recognize it at all.
