01-19-2006 10:32 AM - edited 03-17-2019 08:36 PM
Why i cant use the IP Communicator with VT Advantage?
01-21-2006 11:00 PM
Cisco VT Advantage and Cisco IP Communicator Co-resident on a PC
If you want to run both Cisco VT Advantage and Cisco IP Communicator on the same PC, use these versions:
Cisco VT Advantage version 1.0(2) or higher
Cisco IP Communicator version 1.1(2) or higher
01-24-2006 08:23 AM
The document is a little misleading. You can have this software installed coresident, but they will not work together.
You will need IP Communicator 2.0 with VT Advantage 2.0. Both "should" be available mid 2006.
01-24-2006 01:07 PM
Try the latest version (2.0), it supports the VT Advantage.
