Vta Advantage + ip comunicator
Hello .
Can Vta advantage works with Ipcomunicator?
Try the new VTA version 2.0.2. It works also with web cameras from different vendors unofficial.
Zdravko
z.zdravkov
For sure. On the VTA interface you have button from which you can choose the type ot IP phone that you are working. On the left you have IP communicator on the right hardware IP phone.
Please rate this answer if it helps.
Zdravko
Sorry , but I don?t see this button.
The version of the VTA software es 1.0(2) .
Zdravko
I have updated ip communicator and vta software to 2.0 and all is working fine.
