Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
vwic2-2mft-t1 clocking issue
Have a PRI and point to point T1 terminated to a VWIC2-2MFT-T1 card, when the pri has priority clocking, there are no slips except on the point to point T1 and vice versa. Does anybody know a way around this, both clocks are set to internal. I have read where you can setup independent clocking but only if both are used for data.
I hope that the only answer is not to get 2 separate single port cards.
1 REPLY
Re: vwic2-2mft-t1 clocking issue
If you do a search on this forum, you will see that many people have run into the same issue. To my knowledge, the only workarounds are to use the same carrier for both circuits and ask them to provide the same clocking or live with the slips/errors. The only other option is, as you said, another card.
Hope this helps.
Brandon
163
