What is disconnect cause code 0
kumarss77
What is disconnect cause 0. ?
Enabled CDR logging for VoIP, and in many calls i get disconnect cause code '0', with no disconnect text.
Can some one give more details on what could be the actual reason. Cisco wesite says 'this is just a cosmetic change', then what is the cause?
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094e72.shtml
Brandon Buffin
According to the following link, cause code 0 is No Error. The link in your post above indicates that seeing a lot of these is simply a defect in your version of IOS that has no real impact.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_troubleshooting_guide_chapter09186a0080382d82.html#wp1003773
Hope this helps. If so, please rate the post.
Brandon
I tried now 3 IOS versions, due to various issues.
Any suggestions on any IOS specific to solve this case.
Thank you for the post.
present IOS is
Software (C3845-IPVOICE-M), Version 12.3(14)T6, RELEASE
Router 3845, with 2 dual VIC and one 2 port e1 on NMHDV.
This is the debug isdn q931, and cdr output together.
I have noticed that the reverse call leg generates Disconnect cause code 0, WHEN I WITHDRAW THE DIAL IMMEDIATELY, before getting any response from the other side.
*Mar 18 11:44:10.882: ISDN Se1/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0700
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98387
Exclusive, Channel 7
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '043664710'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '448708508504'
Sending Complete
Locking Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x80
Codeset 5 IE 0x32 i = 0x81
*Mar 18 11:44:10.886: ISDN Se1/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x
8700
*Mar 18 11:44:12.754: ISDN Se1/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0
x0700
Cause i = 0x8190 - Normal call clearing
*Mar 18 11:44:12.754: ISDN Se1/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x87
00
*Mar 18 11:44:12.782: ISDN Se1/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x0700
*Mar 18 11:44:12.782: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId
59A45414 B5AB11DA 97B70013 801E4420, SetupTime *11:44:10.882 UTC Sat Mar 18 2006
, PeerAddress 043664710, PeerSubAddress , DisconnectCause 10 , DisconnectText n
ormal call clearing (16), ConnectTime *11:44:12.762 UTC Sat Mar 18 2006, Disconn
ectTime *11:44:12.762 UTC Sat Mar 18 2006, CallOrigin 2, ChargedUnits 0, InfoTyp
e 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
*Mar 18 11:44:13.070: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId
59A45414 B5AB11DA 97B70013 801E4420, SetupTime *11:44:10.880 UTC Sat Mar 18 2006
, PeerAddress 176608708508504, PeerSubAddress , DisconnectCause 0 , Disconnect
Text , ConnectTime *11:44:13.070 UTC Sat Mar 18 2006, DisconnectTime *11:44:13.0
70 UTC Sat Mar 18 2006, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPacket
s 0, TransmitBytes 0, ReceivePackets 4, ReceiveBytes 44
Skycom3845#
