what is the difference Between CCM 3.3 , CCM 4.X and CCM 5.X
Dear Seniors,
1, I want to know the difference between CCM 3.3 AND CCM 4.1
My second questions
Difference between CCM 4.X and CCM 5.X
pls let me know the above diffrence.
if any body knows , pls answer to my question, it will be helpful to lot of people.
thanks
esa
Re: what is the difference Between CCM 3.3 , CCM 4.X and CCM 5.X
Hi Esa,
At the beginning of the release notes is a section that describes the new and changed information from the previous release.
Here it is for CM 3.3:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_3/rel_note/334cmrn.htm#wp1319190
and for 4.0:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_0/rel_note/402cmrn.htm#wp1708005
and for 5.0:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/5_0/rel_note/504acmrn.pdf
(pdf: you'll have to search for "changed".)
Hope this is helpful.
-Joe
hi Joe. Thank you for u effort and for your help. it is another useful info about the differences.
thanks
esa
CALLMANGER 3.3 HAS LImited funtionality as compare to Callmanager 4.1.3 or 5
Normally Clients that I work with that use CM 4 are working with H323 or MGCP protocol, you can do Sip trunks with CM4,but when I see CM5 the client is providing end to end solution so they need SIP which is what Callmanager 5 differs from callmanger 3 an 4. but there is also Callmanager 6 !
http://tools.cisco.com/E-Learning-IT/LPCM/LpcmLLController?action=CourseDesc&COURSE_ID=5088
106
