1751-V & ATA-186 Incompatibility
Hi There,
I have a VoIP network, of two Cisco 1750-4V, two Cisco 1751-V multiservice routers and two ATA-186 voice gateways.
The communication between any 1750-4V and ATA-186 devices is flawless in both directions. However, when we try to make a call from 1751-V (FXO or FXS port) to the ATA-186, it's impossible. The communication from any ATA-186 to any 1750-4V, the other ATA-186, and any 1751-V (FXO or FXS port) is flawless.
I don't know if a newer version of ATA-186 flash ROM (actually there is 2.07 version) will solve this problem?
I will appreciate any comments.
Igor Sotelo.
Silver
Re: 1751-V & ATA-186 Incompatibility
I have a setup in which ATA-186 and 1751-V are interopearting without any issues. My setup is similar to the one in the document http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a0080094669.shtml.
Thank you for the information.
We don't use a gatekeeper, and I have the following configuration on both 1751-V (the configuration is the same on the 1750-4V's):
dial-peer voice 5000 voip
.destination-pattern 500.
.session target ipv4:x.y.z.w
where x.y.z.w is a external valid IP address.
On the ATA-186 we have configured:
static IP: x.y.z.w
static net mask: 255.255.255.240
UID0: 5000
UID1: 5001
and static route: x.y.z.w1
I can ping the devices from the 1751-V without problems, and also call the 1751-V from the ATA. However, I can't call the ATA from the 1751-V.
Do you have idea, of what can be wrong?
Igor Sotelo.
238
