18 sec silent between dialing digits and ring back tone
We have VoIP setup that connect branch offices through the head office PBX .(calls cross the E1 link twice that connect 3662 & PBX).
When call progress between two 1751 2V, there is a 18 second silent between dialing digits and getting ring back tone.
This seems not to be happened between 1750 2v.
Can anybody give me a suggestion to decrease this delay or add some tone to this silent period?
Re: 18 sec silent between dialing digits and ring back tone
Hi all,
I'm encountering some VOIP problems. I have
problems getting calls to a remote site.
IOS,Version 12.2(11)T
FXO --- PABX ---E1/R2--- AS5400---IP---2621---E1/R2----PABX --- FXO
controller E1 6/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
ds0 busyout 27-31 soft
cas-custom 0
country brazil
metering
seizure-ack-time 2
category 2
answer-signal group-b 1
dnis-digits min 3 max 12
answer-guard-time 1
description *** AS5400 / PABX ***
Regards;
hi,everyone:
i am working in constructing a voip system. the system can provide the voip service from AS5400 with fxo port to Pabx siemens Hicon 300 with E1/R2.
Can anybody give me a suggestion to decrease this delay and add some tone to this silent period?
pls help me to find out how to solve the problem. the related problem information is above:
Pl. post the config here fromthe gateway. 180 secs is too long for ringback tone. Any config differences you have seen between 1720 and 150?
Also enable the debug for "debug voip ccapi inout" for that call to see what is going on till 18 secs.
Make sure that the milisecond timestamps in the debug it tuned on using
service timestamps debug date msec
Thanks for your help.. here are the config fragments taken fron 1750 & 1751.
I have the debug output when call initiated from 1751 & 1750 to the extentions behind the PBX.(TP----- 175X----3662----PBX-----TP) ,
1750
voice-port 2/0
voice-port 2/1
voice class codec 1
codec preference 1 g729r8
dial-peer voice 1 pots
destination-pattern 6030
port 2/0
dial-peer voice 3 voip
destination-pattern 1...
voice-class codec 1
session target ipv4:192.168.10.210
dial-peer voice 4 voip
destination-pattern 6...
voice-class codec 1
--More-- !
1751
version 12.2
voice call send-alert
voice rtp send-recv
voice class codec 1
--More-- codec preference 1 g729r8
call rsvp-sync
voice-port 2/0
voice-port 2/1
dial-peer cor custom
port 2/0
--More-- destination-pattern 1...
voice-class codec 1
voice-class codec 1
What kind of signalling you have on E1 lines? Also now need to see the debug for "debug voip ccapi inout" as i have requested in my earlier reply with msec timestamp.
Signalling is R2 analog
Pls see the debug for 1750 below.. and 1751 will be in following posting..
Router1750#
*Mar 1 00:28:06.743: cc_api_call_setup_ind (vdbPtr=0x8158DE0C, callInfo={called=, calling=6030, fdest=0 peer_tag=1}, callID=0x815D8400)
*Mar 1 00:28:06.743: cc_process_call_setup_ind (event=0x815849F4) handed call to app "SESSION"
*Mar 1 00:28:06.747: sess_appl: ev(23=CC_EV_CALL_SETUP_IND), cid(25), disp(0)
*Mar 1 00:28:06.747: ccCallSetContext (callID=0x19, context=0x815E7CF0)
*Mar 1 00:28:06.747: ccCallSetupAck (callID=0x19)
*Mar 1 00:28:06.747: ccGenerateTone (callID=0x19 tone=8)
*Mar 1 00:28:09.063: cc_api_call_digit_begin (vdbPtr=0x8158DE0C, callID=0x19, digit=1, flags=0x1, timestamp=0xFC172B74, expiration=0x0)
*Mar 1 00:28:09.063: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(25), disp(0)
*Mar 1 00:28:09.063: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.063: ssaIgnore cid(25), st(0),oldst(0), ev(10)
*Mar 1 00:28:09.143: cc_api_call_digit (vdbPtr=0x8158DE0C, callID=0x19, digit=1, duration=130)
*Mar 1 00:28:09.143: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(25), disp(0)
*Mar 1 00:28:09.143: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.271: cc_api_call_digit_begin (vdbPtr=0x8158DE0C, callID=0x19, digit=1, flags=0x1, timestamp=0xFC172B74, expiration=0x0)
*Mar 1 00:28:09.271: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(25), disp(0)
*Mar 1 00:28:09.271: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.275: ssaIgnore cid(25), st(0),oldst(0), ev(10)
*Mar 1 00:28:09.351: cc_api_call_digit (vdbPtr=0x8158DE0C, callID=0x19, digit=1, duration=130)
*Mar 1 00:28:09.351: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(25), disp(0)
*Mar 1 00:28:09.355: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.571: cc_api_call_digit_begin (vdbPtr=0x8158DE0C, callID=0x19, digit=7, flags=0x1, timestamp=0xFC172B74, expiration=0x0)
*Mar 1 00:28:09.571: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(25), disp(0)
*Mar 1 00:28:09.571: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.575: ssaIgnore cid(25), st(0),oldst(0), ev(10)
*Mar 1 00:28:09.651: cc_api_call_digit (vdbPtr=0x8158DE0C, callID=0x19, digit=7, duration=130)
*Mar 1 00:28:09.651: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(25), disp(0)
*Mar 1 00:28:09.655: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.951: cc_api_call_digit_begin (vdbPtr=0x8158DE0C, callID=0x19, digit=9, flags=0x1, timestamp=0xFC172B74, expiration=0x0)
*Mar 1 00:28:09.951: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(25), disp(0)
*Mar 1 00:28:09.955: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:09.955: ssaIgnore cid(25), st(0),oldst(0), ev(10)
*Mar 1 00:28:10.031: cc_api_call_digit (vdbPtr=0x8158DE0C, callID=0x19, digit=9, duration=130)
*Mar 1 00:28:10.031: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(25), disp(0)
*Mar 1 00:28:10.035: ssaTraceSct: cid(25)st(0)oldst(0)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:28:10.035: ssaSetupPeer cid(25) peer list: tag(3) called number (1179)
*Mar 1 00:28:10.035: ssaSetupPeer cid(25), destPat(1179), matched(1), prefix(), peer(8154C994)
*Mar 1 00:28:10.035: ccCallProceeding (callID=0x19, prog_ind=0x0)
*Mar 1 00:28:10.035: ccCallSetupRequest (Inbound call = 0x19, outbound peer =3, dest=, params=0x815E7D04 mode=0, *callID=0x8158A180)
*Mar 1 00:28:10.035: callingNumber=6030, calledNumber=1179, redirectNumber=
*Mar 1 00:28:10.035: accountNumber=, finalDestFlag=0,
guid=97ed.6f95.d326.002f.0000.0000.0019.bcd4
*Mar 1 00:28:10.035: peer_tag=3
*Mar 1 00:28:10.035: ccIFCallSetupRequest: (vdbPtr=0x814D3418, dest=, callParams={called=1179, calling=6030, fdest=0, voice_peer_tag=3}, mode=0x0)
*Mar 1 00:28:10.039: ccCallSetContext (callID=0x1A, context=0x815E693C)
*Mar 1 00:28:10.067: cc_api_call_proceeding(vdbPtr=0x814D3418, callID=0x1A,
prog_ind=0x0)
*Mar 1 00:28:10.067: sess_appl: ev(20=CC_EV_CALL_PROCEEDING), cid(26), disp(0)
*Mar 1 00:28:10.067: ssaTraceSct: cid(26)st(1)oldst(0)cfid(-1)csize(0)in(0)fDest(0)-cid2(25)st2(1)oldst2(0)
*Mar 1 00:28:10.067: ssaIgnore cid(26), st(1),oldst(1), ev(20)
*Mar 1 00:28:12.835: cc_api_call_alert(vdbPtr=0x814D3418, callID=0x1A, prog_ind=0x8, sig_ind=0x1)
*Mar 1 00:28:12.839: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(26), disp(0)
*Mar 1 00:28:12.839: ssaTraceSct: cid(26)st(1)oldst(1)cfid(-1)csize(0)in(0)fDest(0)-cid2(25)st2(1)oldst2(0)
*Mar 1 00:28:12.839: ccCallAlert (callID=0x19, prog_ind=0x8, sig_ind=0x1)
*Mar 1 00:28:12.839: ccConferenceCreate (confID=0x8158A1C8, callID1=0x19, callID2=0x1A, tag=0x0)
*Mar 1 00:28:12.843: cc_api_bridge_done (confID=0x8, srcIF=0x814D3418, srcCallID=0x1A, dstCallID=0x19, disposition=0, tag=0x0)
*Mar 1 00:28:12.859: cc_api_bridge_done (confID=0x8, srcIF=0x8158DE0C, srcCallID=0x19, dstCallID=0x1A, disposition=0, tag=0x0)
*Mar 1 00:28:12.859: cc_api_caps_ind (dstVdbPtr=0x814D3418, dstCallId=0x1A, srcCallId=0x19,
caps={codec=0xEBFB, fax_rate=0x7F, vad=0x3, modem=0x801453F4
codec_bytes=0, signal_type=3})
*Mar 1 00:28:12.875: sess_appl: ev(28=CC_EV_CONF_CREATE_DONE), cid(25), disp(0)
*Mar 1 00:28:12.875: ssaTraceSct: cid(25)st(3)oldst(0)cfid(8)csize(0)in(1)fDest(0)-cid2(26)st2(3)oldst2(1)
*Mar 1 00:28:13.063: cc_api_caps_ind (dstVdbPtr=0x8158DE0C, dstCallId=0x19, srcCallId=0x1A,
caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x1
codec_bytes=20, signal_type=0})
*Mar 1 00:28:13.063: cc_api_caps_ack (dstVdbPtr=0x8158DE0C, dstCallId=0x19, srcCallId=0x1A,
*Mar 1 00:28:13.075: cc_api_caps_ack (dstVdbPtr=0x814D3418, dstCallId=0x1A, srcCallId=0x19,
*Mar 1 00:28:19.415: cc_api_call_connected(vdbPtr=0x814D3418, callID=0x1A)
*Mar 1 00:28:19.419: sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(26), disp(0)
*Mar 1 00:28:19.419: ssaTraceSct: cid(26)st(4)oldst(1)cfid(8)csize(0)in(0)fDest(0)-cid2(25)st2(4)oldst2(3)
*Mar 1 00:28:19.419: ccCallConnect (callID=0x19)
*Mar 1 00:28:19.419: ssaFlushPeerTagQueue cid(25) peer list: (empty)
*Mar 1 00:28:20.031: cc_api_call_digit (vdbPtr=0x8158DE0C, callID=0x19, digit=T, duration=0)
*Mar 1 00:28:20.031: sess_appl: ev(9=CC_EV_CALL_DIGIT), cid(25), disp(0)
*Mar 1 00:28:20.031: ssaTraceSct: cid(25)st(5)oldst(3)cfid(8)csize(0)in(1)fDest(0)-cid2(26)st2(5)oldst2(4)
*Mar 1 00:28:21.139: cc_api_call_disconnected(vdbPtr=0x8158DE0C, callID=0x19, cause=0x10)
*Mar 1 00:28:21.139: sess_appl: ev(12=CC_EV_CALL_DISCONNECTED), cid(25), disp(0)
*Mar 1 00:28:21.139: ssaTraceSct: cid(25)st(5)oldst(5)cfid(8)csize(0)in(1)fDest(0)-cid2(26)st2(5)oldst2(4)
*Mar 1 00:28:21.139: ssa: Disconnected cid(25) state(5) cause(0x10)
*Mar 1 00:28:21.139: ccConferenceDestroy (confID=0x8, tag=0x0)
*Mar 1 00:28:21.139: cc_api_bridge_drop_done (confID=0x8, srcIF=0x814D3418, srcCallID=0x1A, dstCallID=0x19, disposition=0 tag=0x0)
*Mar 1 00:28:21.139: cc_api_bridge_drop_done (confID=0x8, srcIF=0x8158DE0C, srcCallID=0x19, dstCallID=0x1A, disposition=0 tag=0x0)
*Mar 1 00:28:21.143: sess_appl: ev(29=CC_EV_CONF_DESTROY_DONE), cid(25), disp(0)
*Mar 1 00:28:21.143: ssaTraceSct: cid(25)st(6)oldst(5)cfid(-1)csize(0)in(1)fDest(0)-cid2(26)st2(6)oldst2(4)
*Mar 1 00:28:21.143: ccCallDisconnect (callID=0x19, cause=0x10 tag=0x0)
*Mar 1 00:28:21.143: ccCallDisconnect (callID=0x1A, cause=0x10 tag=0x0)
*Mar 1 00:28:21.155: cc_api_call_disconnect_done(vdbPtr=0x814D3418, callID=0x1A, disp=0, tag=0x0)
*Mar 1 00:28:21.163: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(26), disp(0)
*Mar 1 00:28:21.163: ssaTraceSct: cid(26)st(7)oldst(4)cfid(-1)csize(0)in(0)fDest(0)-cid2(25)st2(7)oldst2(6)
*Mar 1 00:28:21.167: cc_api_call_disconnect_done(vdbPtr=0x8158DE0C, callID=0x19, disp=0, tag=0x0)
*Mar 1 00:28:21.167: sess_appl: ev(13=CC_EV_CALL_DISCONNECT_DONE), cid(25), disp(0)
*Mar 1 00:28:21.167: ssaTraceSct: cid(25)st(7)oldst(6)cfid(-1)csize(1)in(1)fDest(0)
debug for 1751 part 1
*Mar 1 00:04:20.935: cc_api_call_setup_ind (vdbPtr=0x819546C8, callInfo={called=,called_oct3=0x81,calling=,calling_oct3=0x0,calling_oct3a=0x0,calling_xlated=false,subscriber_type_str=RegularLine,fdest=0,peer_tag=1, prog_ind=3,callingIE_present 0},callID=0x81918E30)
*Mar 1 00:04:20.935: cc_api_call_setup_ind calling number is null, answer addr dest pattern 6030 e164_ans_addr 0 e164_dest_pattern 1
*Mar 1 00:04:20.935: cc_api_call_setup_ind valid dest pattern, copying 6030 to calling number
*Mar 1 00:04:20.935: cc_api_call_setup_ind type 3 , prot 0
*Mar 1 00:04:20.935: cc_insert_call_entry: Increment call volume counter
*Mar 1 00:04:20.935: cc_insert_call_entry: current call volume: 1
*Mar 1 00:04:20.935: cc_insert_call_entry: entry's incoming TRUE. is_incoming is TRUE
*Mar 1 00:04:20.939: cc_incr_if_call_volume: not the VoIP or MMoIP
*Mar 1 00:04:20.939: cc_process_call_setup_ind (event=0x8193FBF4)
*Mar 1 00:04:20.939: >>>>CCAPI handed cid 2 with tag 1 to app "DEFAULT"
*Mar 1 00:04:20.939: sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(2), disp(0)
*Mar 1 00:04:20.943: sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(2), disp(0)
*Mar 1 00:04:20.943: ssaCallSetupInd
*Mar 1 00:04:20.943: ccCallSetContext (callID=0x2, context=0x81853F50)
*Mar 1 00:04:20.943: ssaCallSetupInd cid(2), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 0
*Mar 1 00:04:20.943: ccCallSetupAck (callID=0x2)
*Mar 1 00:04:20.943: cc_api_set_transfer_info: (transfer= 0, callID=0x2)
*Mar 1 00:04:20.943: cc_api_set_transfer_info: call transfer reset)
*Mar 1 00:04:20.943: ccGenerateToneInfo (callID=0x2 tone=8)
*Mar 1 00:04:20.943: ccCallReportDigits (callID=0x2, enable=0x1)
*Mar 1 00:04:20.943: cc_api_call_report_digits_done (vdbPtr=0x819546C8, callID=0x2, disp=0)
*Mar 1 00:04:20.943: sess_appl: ev(52=CC_EV_CALL_REPORT_DIGITS_DONE), cid(2), disp(0)
*Mar 1 00:04:20.943: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:04:20.947: ssaReportDigitsDone cid(2) peer list: (empty)
*Mar 1 00:04:20.947: ssaReportDigitsDone callid=2 Enable succeeded
*Mar 1 00:04:20.947: ccGenerateToneInfo (callID=0x2 tone=8)
*Mar 1 00:04:22.883: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=1, digit_begin_flags=0x1, rtp_timestamp=0xEE81E9A3
rtp_expiration=0x0, dest_mask=0x1)
*Mar 1 00:04:22.887: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(2), disp(0)
*Mar 1 00:04:22.887: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
*Mar 1 00:04:22.887: ssaIgnore cid(2), st(SSA_CS_MAPPING),oldst(0), ev(10)
*Mar 1 00:04:22.963: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=1,duration=115,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
*Mar 1 00:04:22.963: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(2), disp(0)
*Mar 1 00:04:22.967: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
*Mar 1 00:04:22.967: ssaDigit
*Mar 1 00:04:22.967: ssaDigit, 0. sct->digit , sct->digit len 0, usrDigit 1, digit_tone_mode=0
*Mar 1 00:04:22.967: ssaDigit,1. callinfo.called , digit 1, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
*Mar 1 00:04:22.967: ssaDigit, 7. callinfo.calling 6030, sct->digit 1, result 1
*Mar 1 00:04:23.095: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
*Mar 1 00:04:23.095: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(2), disp(0)
*Mar 1 00:04:23.095: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
*Mar 1 00:04:23.095: ssaIgnore cid(2), st(SSA_CS_MAPPING),oldst(0), ev(10)
*Mar 1 00:04:23.175: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
*Mar 1 00:04:23.175: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(2), disp(0)
*Mar 1 00:04:23.175: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
*Mar 1 00:04:23.175: ssaDigit
*Mar 1 00:04:23.175: ssaDigit, 0. sct->digit 1, sct->digit len 1, usrDigit 1, digit_tone_mode=0
*Mar 1 00:04:23.175: ssaDigit,1. callinfo.called , digit 11, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
*Mar 1 00:04:23.175: ssaDigit, 7. callinfo.calling 6030, sct->digit 11, result 1
*Mar 1 00:04:23.443: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=7, digit_begin_flags=0x1, rtp_timestamp=0xEE81E9A3
*Mar 1 00:04:23.447: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(2), disp(0)
*Mar 1 00:04:23.447: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
*Mar 1 00:04:23.447: ssaIgnore cid(2), st(SSA_CS_MAPPING),oldst(0), ev(10)
*Mar 1 00:04:23.523: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=7,duration=115,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
*Mar 1 00:04:23.523: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(2), disp(0)
*Mar 1 00:04:23.527: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
*Mar 1 00:04:23.527: ssaDigit
*Mar 1 00:04:23.527: ssaDigit, 0. sct->digit 11, sct->digit len 2, usrDigit 7, digit_tone_mode=0
*Mar 1 00:04:23.527: ssaDigit,1. callinfo.called , digit 117, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
*Mar 1 00:04:23.527: ssaDigit, 7. callinfo.calling 6030, sct->digit 117, result 1
*Mar 1 00:04:23.855: cc_api_call_digit_begin (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=9, digit_begin_flags=0x1, rtp_timestamp=0xEE81E9A3
*Mar 1 00:04:23.855: sess_appl: ev(10=CC_EV_CALL_DIGIT_BEGIN), cid(2), disp(0)
*Mar 1 00:04:23.855: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_DIGIT_BEGIN)
*Mar 1 00:04:23.855: ssaIgnore cid(2), st(SSA_CS_MAPPING),oldst(0), ev(10)
*Mar 1 00:04:23.955: cc_api_call_digit_end (dstVdbPtr=0x0, dstCallId=0xFFFFFFFF, srcCallId=0x2,
digit=9,duration=135,xruleCallingTag=0,xruleCalledTag=0, dest_mask=0x1), digit_tone_mode=0
*Mar 1 00:04:23.955: sess_appl: ev(9=CC_EV_CALL_DIGIT_END), cid(2), disp(0)
*Mar 1 00:04:23.955: cid(2)st(SSA_CS_MAPPING)ev(SSA_EV_CALL_DIGIT)
*Mar 1 00:04:23.955: ssaDigit
*Mar 1 00:04:23.955: ssaDigit, 0. sct->digit 117, sct->digit len 3, usrDigit 9, digit_tone_mode=0
*Mar 1 00:04:23.959: ssaDigit,1. callinfo.called , digit 1179, callinfo.calling 6030, xrulecallingtag 0, xrulecalledtag 0
*Mar 1 00:04:23.959: ssaDigit, 7. callinfo.calling 6030, sct->digit 1179, result 0
*Mar 1 00:04:23.959: ccCallReportDigits (callID=0x2, enable=0x0)
*Mar 1 00:04:23.959: cc_api_call_report_digits_done (vdbPtr=0x819546C8, callID=0x2, disp=0)
*Mar 1 00:04:23.959: ssaSetupPeer cid(2) peer list: tag(3) called number (1179)
*Mar 1 00:04:23.959: ssaSetupPeer cid(2), destPat(1179), matched(1), prefix(), peer(8191BA0C), peer->encapType (2)
*Mar 1 00:04:23.959: ccCallProceeding (callID=0x2, prog_ind=0x0)
*Mar 1 00:04:23.959: ccCallSetupRequest (Inbound call = 0x2, outbound peer =3, dest=, params=0x8194FDE0 mode=0, *callID=0x81950210, prog_ind = 3) callingIE_present 0
*Mar 1 00:04:23.959: ccCallSetupRequest numbering_type 0x81
*Mar 1 00:04:23.963: ccCallSetupRequest encapType 2 clid_restrict_disable 1 null_orig_clg 1 clid_transparent 0 callingNumber 6030
*Mar 1 00:04:23.963: dest pattern 1..., called 1179, digit_strip 0
*Mar 1 00:04:23.963: callingNumber=6030, calledNumber=1179, redirectNumber= display_info= calling_oct3a=0
*Mar 1 00:04:23.963: accountNumber=, finalDestFlag=0,
guid=2354.2999.14ef.11cc.8008.bb84.44aa.06a5
*Mar 1 00:04:23.963: peer_tag=3
*Mar 1 00:04:23.963: ccIFCallSetupRequestPrivate: (vdbPtr=0x818A8AE0, dest=, callParams={called=1179,called_oct3=0x81, calling=6030,calling_oct3=0x0, calling_xlated=false, subscriber_type_str=RegularLine, fdest=0, voice_peer_tag=3},mode=0x0) vdbPtr type = 1
*Mar 1 00:04:23.963: ccIFCallSetupRequestPrivate: (vdbPtr=0x818A8AE0, dest=, callParams={called=1179, called_oct3 0x81, calling=6030,calling_oct3 0x0, calling_xlated=false, fdest=0, voice_peer_tag=3}, mode=0x0, xltrc=-5)
*Mar 1 00:04:23.963: cc_insert_call_entry: not incoming entry
*Mar 1 00:04:23.963: cc_insert_call_entry: entry's incoming FALSE. is_incoming is FALSE
*Mar 1 00:04:23.967: ccSaveDialpeerTag (callID=0x2, dialpeer_tag=0x3)
*Mar 1 00:04:23.967: ccCallSetContext (callID=0x3, context=0x81854A68)
*Mar 1 00:04:23.967: sess_appl: ev(52=CC_EV_CALL_REPORT_DIGITS_DONE), cid(2), disp(0)
*Mar 1 00:04:23.967: cid(2)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
*Mar 1 00:04:23.967: -cid2(3)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_MAPPING)
*Mar 1 00:04:23.967: ssaReportDigitsDone cid(2) peer list: (empty)
*Mar 1 00:04:23.967: ssaReportDigitsDone callid=2 Reporting disabled.
*Mar 1 00:04:23.967: cc_api_supported_data data_mode=0x10002
*Mar 1 00:04:23.971: cc_incr_if_call_volume: remote IP is 192.168.10.210
*Mar 1 00:04:23.971: cc_incr_if_call_volume: hwidb is FastEthernet0/0
*Mar 1 00:04:23.971: cc_incr_if_call_volume: create entry in list: 1
*Mar 1 00:04:25.975: ccTDUtilGetInstanceCount: For tagID[1] of callID[3]
*Mar 1 00:04:25.975: ccTDPvtProfileTableObjectAccessManager: No profileTable set for callID[3]
*Mar 1 00:04:25.975: ccTDUtilGetInstanceCount: For tagID[2] of callID[3]
1751 debug part 2
*Mar 1 00:04:25.987: cc_api_call_proceeding(vdbPtr=0x818A8AE0, callID=0x3,
prog_ind=0x0, rawmsgPtr=0x0)
*Mar 1 00:04:25.987: sess_appl: ev(21=CC_EV_CALL_PROCEEDING), cid(3), disp(0)
*Mar 1 00:04:25.991: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_PROCEEDING)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 1 00:04:25.991: -cid2(2)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 1 00:04:25.991: ssaCallProc
*Mar 1 00:04:25.991: ccGetDialpeerTag (callID=0x2)
*Mar 1 00:04:25.991: ssaIgnore cid(3), st(SSA_CS_CALL_SETTING),oldst(1), ev(21)
*Mar 1 00:04:38.679: cc_api_call_alert(vdbPtr=0x818A8AE0, callID=0x3, prog_ind=0x8, sig_ind=0x1)
*Mar 1 00:04:38.683: sess_appl: ev(7=CC_EV_CALL_ALERT), cid(3), disp(0)
*Mar 1 00:04:38.683: cid(3)st(SSA_CS_CALL_SETTING)ev(SSA_EV_CALL_ALERT)
oldst(SSA_CS_CALL_SETTING)cfid(-1)csize(0)in(0)fDest(0)
*Mar 1 00:04:38.683: -cid2(2)st2(SSA_CS_CALL_SETTING)oldst2(SSA_CS_CALL_SETTING)
*Mar 1 00:04:38.683: ssaAlert
*Mar 1 00:04:38.683: ccGetDialpeerTag (callID=0x2)
*Mar 1 00:04:38.683: ccCallAlert (callID=0x2, prog_ind=0x8, sig_ind=0x1)
*Mar 1 00:04:38.683: ccConferenceCreate (confID=0x81950684, callID1=0x2, callID2=0x3, tag=0x0)
*Mar 1 00:04:38.683: cc_api_bridge_done (confID=0x1, srcIF=0x818A8AE0, srcCallID=0x3, dstCallID=0x2, disposition=0, tag=0x0)
*Mar 1 00:04:38.687: cc_api_bridge_done (confID=0x1, srcIF=0x819546C8, srcCallID=0x2, dstCallID=0x3, disposition=0, tag=0x0)
*Mar 1 00:04:38.687: cc_api_caps_ind (dstVdbPtr=0x818A8AE0, dstCallId=0x3, srcCallId=0x2,
caps={codec=0xFBFF, fax_rate=0xBF, vad=0x3, modem=0x2
*Mar 1 00:04:38.687: cc_api_caps_ind (Playout: mode 0, initial 60,min 40, max 300)
*Mar 1 00:04:38.687: cc_api_caps_ind (dstVdbPtr=0x819546C8, dstCallId=0x2, srcCallId=0x3,
caps={codec=0x4, fax_rate=0x2, vad=0x2, modem=0x0
codec_bytes=20, signal_type=2})
*Mar 1 00:04:38.687: cc_api_caps_ack (dstVdbPtr=0x819546C8, dstCallId=0x2, srcCallId=0x3,
codec_bytes=20, signal_type=2, seq_num_start=996})
*Mar 1 00:04:38.687: cc_api_caps_ack (dstVdbPtr=0x818A8AE0, dstCallId=0x3, srcCallId=0x2,
*Mar 1 00:04:38.691: cc_api_voice_mode_event , callID=0x2
*Mar 1 00:04:38.691: Call Pointer =81853F50
*Mar 1 00:04:38.691: sess_appl: ev(29=CC_EV_CONF_CREATE_DONE), cid(2), disp(0)
*Mar 1 00:04:38.691: cid(2)st(SSA_CS_CONFERENCING_ALERT)ev(SSA_EV_CONF_CREATE_DONE)
oldst(SSA_CS_CALL_SETTING)cfid(1)csize(0)in(1)fDest(0)
*Mar 1 00:04:38.691: -cid2(3)st2(SSA_CS_CONFERENCING_ALERT)oldst2(SSA_CS_CALL_SETTING)
*Mar 1 00:04:38.691: ssaConfCreateDoneAlert
*Mar 1 00:04:38.691: sess_appl: ev(50=CC_EV_VOICE_MODE_DONE), cid(2), disp(0)
*Mar 1 00:04:38.695: cid(2)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_VOICE_MODE_DONE)
oldst(SSA_CS_CONFERENCING_ALERT)cfid(1)csize(0)in(1)fDest(0)
*Mar 1 00:04:38.695: -cid2(3)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CALL_SETTING)
*Mar 1 00:04:38.695: ssaIgnore cid(2), st(SSA_CS_CONFERENCED_ALERT),oldst(4), ev(50)
*Mar 1 00:04:38.695: cc_process_notify_bridge_done (event=0x81944D54)
*Mar 1 00:04:45.603: cc_api_call_connected(vdbPtr=0x818A8AE0, callID=0x3), prog_ind = 2cc_api_call_connected: setting callEntry->connected to TRUE
*Mar 1 00:04:45.603: sess_appl: ev(8=CC_EV_CALL_CONNECTED), cid(3), disp(0)
*Mar 1 00:04:45.603: cid(3)st(SSA_CS_CONFERENCED_ALERT)ev(SSA_EV_CALL_CONNECTED)
oldst(SSA_CS_CALL_SETTING)cfid(1)csize(0)in(0)fDest(0)
*Mar 1 00:04:45.603: -cid2(2)st2(SSA_CS_CONFERENCED_ALERT)oldst2(SSA_CS_CONFERENCED_ALERT)
*Mar 1 00:04:45.603: ssaConnectAlert
*Mar 1 00:04:45.603: ccGetDialpeerTag (callID=0x2)
*Mar 1 00:04:45.607: ccCallConnect (callID=0x2), prog_ind = 2ccCallConnect: setting callEntry->connected to TRUE
*Mar 1 00:04:45.607: ssaFlushPeerTagQueue cid(2) peer list: (empty)
*Mar 1 00:04:48.827: cc_api_call_disconnected(vdbPtr=0x819546C8, callID=0x2, cause=0x10)
*Mar 1 00:04:48.827: sess_appl: ev(11=CC_EV_CALL_DISCONNECTED), cid(2), disp(0)
*Mar 1 00:04:48.827: cid(2)st(SSA_CS_ACTIVE)ev(SSA_EV_CALL_DISCONNECTED)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(1)csize(0)in(1)fDest(0)
*Mar 1 00:04:48.827: -cid2(3)st2(SSA_CS_ACTIVE)oldst2(SSA_CS_CONFERENCED_ALERT)
*Mar 1 00:04:48.827: ssa: Disconnected cid(2) state(5) cause(0x10)
*Mar 1 00:04:48.827: ccConferenceDestroy (confID=0x1, tag=0x0)
*Mar 1 00:04:48.827: cc_api_bridge_drop_done (confID=0x1, srcIF=0x818A8AE0, srcCallID=0x3, dstCallID=0x2, disposition=0 tag=0x0)
*Mar 1 00:04:48.827: cc_api_bridge_drop_done (confID=0x1, srcIF=0x819546C8, srcCallID=0x2, dstCallID=0x3, disposition=0 tag=0x0)
*Mar 1 00:04:48.831: sess_appl: ev(30=CC_EV_CONF_DESTROY_DONE), cid(2), disp(0)
*Mar 1 00:04:48.831: cid(2)st(SSA_CS_CONF_DESTROYING)ev(SSA_EV_CONF_DESTROY_DONE)
oldst(SSA_CS_ACTIVE)cfid(-1)csize(0)in(1)fDest(0)
*Mar 1 00:04:48.831: -cid2(3)st2(SSA_CS_CONF_DESTROYING)oldst2(SSA_CS_CONFERENCED_ALERT)
*Mar 1 00:04:48.831: ssaConfDestroyDone
*Mar 1 00:04:48.831: ccCallDisconnect (callID=0x2, cause=0x10 tag=0x0)
*Mar 1 00:04:48.831: cc_api_get_transfer_info: (callID=0x2)
*Mar 1 00:04:48.831: ccCallDisconnect (callID=0x3, cause=0x10 tag=0x0)
*Mar 1 00:04:48.831: cc_api_get_transfer_info: (callID=0x3)
*Mar 1 00:04:48.839: cc_api_icpif: expect factor = 0
*Mar 1 00:04:48.843: cc_decr_if_call_volume: the remote IP is 192.168.10.210
*Mar 1 00:04:48.843: cc_decr_if_call_volume: hwidb is FastEthernet0/0
*Mar 1 00:04:48.843: cc_decr_if_call_volume: reduce callnum of entry: 0, voip: 0, mmoip: 0
*Mar 1 00:04:48.843: cc_decr_if_call_volume: remove an entry
*Mar 1 00:04:48.843: cc_api_call_disconnect_done(vdbPtr=0x818A8AE0, callID=0x3, disp=0, tag=0x0)
*Mar 1 00:04:48.843: cc_delete_call_entry: not incoming entry
*Mar 1 00:04:48.843: cc_delete_call_entry: entry's incoming FALSE. is_incoming is FALSE
*Mar 1 00:04:48.847: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(3), disp(0)
*Mar 1 00:04:48.847: cid(3)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONFERENCED_ALERT)cfid(-1)csize(0)in(0)fDest(0)
*Mar 1 00:04:48.847: -cid2(2)st2(SSA_CS_DISCONNECTING)oldst2(SSA_CS_CONF_DESTROYING)
*Mar 1 00:04:48.847: ssaDisconnectDone
*Mar 1 00:04:48.851: cc_decr_if_call_volume: not the VoIP or MMoIP
*Mar 1 00:04:48.851: cc_api_call_disconnect_done(vdbPtr=0x819546C8, callID=0x2, disp=0, tag=0x0)
*Mar 1 00:04:48.851: cc_delete_call_entry: Decrement call volume counter
*Mar 1 00:04:48.851: cc_delete_call_entry: current call volume: 0
*Mar 1 00:04:48.855: cc_delete_call_entry: entry's incoming TRUE. is_incoming is TRUE
*Mar 1 00:04:48.855: sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(2), disp(0)
*Mar 1 00:04:48.855: cid(2)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_CONF_DESTROYING)cfid(-1)csize(1)in(1)fDest(0)
*Mar 1 00:04:48.855: ssaDisconnectDone
Router#
192
