Community Member
2620 - Low voice quality with Nortel - why ?
Hi, All!
Our equipment:
Nortel Meridian 1 option 11
cisco 2620 with NM-HDV+VWIC-MFT E1.
M1/11 connected with 2620 by E1 CAS R2.
Test scheme:
Phone1--M1/11-E1 CAS R2-2620+NM-HDV+MFT--LAN--5350--E1 PRI--M1/81--Phone2
During the call from phone1 to phone2 we have
low voice quality on phone2(noise, fuss)
and normal voice quality on phone1.
How troubleshoote this ?
Help plz!!!!
config:
controller E1 1/0
framing NO-CRC4
ds0-group 1 timeslots 1 type r2-analog dtmf dnis
dial-peer voice 1 voip
destination-pattern 7095T
session target ipv4:3.2.2.1
fax protocol t38 ls-redundancy 5 hs-redundancy 2
no vad
sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(1), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 27-Apr-01 16:15 by cmong
Image text-base: 0x80008088, data-base: 0x810301C4
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
System returned to ROM by reload
System image file is "flash:c2600-is-mz.122-1.bin"
cisco 2620 (MPC860) processor (revision 0x200) with 59392K/6144K bytes of memory
Processor board ID JAD05060VJ3 (3426913788)
M860 processor: part number 0, mask 49
Slot 1:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : F1
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAB05170906
VIC Slot 0:
E1 (1 Port) Multi-Flex Trunk WAN Daughter Card
Hardware revision 1.0 Board revision B0
Serial number 24240279 Part number 800-04475-02
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 21 01 00 01 71 E0 97 50 11 7B 02 00 00 00 00
0x30: 58 00 00 00 00 12 28 00 FF FF FF FF FF FF FF FF
HDV firmware: Compiled Wed 04-Oct-00 20:58 by mani
HDV memory size 524280 heap free 203145
1 REPLY
Re: 2620 - Low voice quality with Nortel - why ?
The first thing is to determin is the voip side is having any problems. Are the issues heard in only one direction or both? You can do a sh call active voice for this call and see what you are getting for the DSP stats. IF you see buffer over flow discards or any mof the concealment counters incrementing, there is probably a QOS issue somewhere in the IP network.
301
