2650XM integration with PABX Panasonic
I need to integrate a 2650XM with VWIC-1MFT-E1 with PBX Panasonic KXT336. The implementation is based on VoFR.The E1 type is E&M immediate-start. The problem is the call is not completed. I get 'sized' status on timeslot, but the busyout is listened. The dial-peers are correct. The PBX is configured with E&M immediate, but doesn't work. I attached the show tech-support and debug files. Any help will be valid.
Romulo
Bronze
Re: 2650XM integration with PABX Panasonic
This is asimilar kind of setup in which it tlks abt the integration PBX with 2600 series. Please have a look at it.
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800a96c1.shtml#int
Romulo,
Check the dial string format on both sides. The called number was rejected by the PBX.
Tony Tan
ttan@dccil.com
214
