Community Member
2650XM with FXO port
I need a sample config for a 2650XM with FXO ports that will be used to route incoming calls to a particular group and that same group will be making calls out that same gateway. I am on CCM 3.3(3)sr3.
If anyone can help me or point me to documentation that would help I would greatly appreciate it.
Re: 2650XM with FXO port
Here is some information -
For a basic H323 gateway, the following would work :
interface ethernet 0/0
ip address
h323-gateway voip bind srcaddr
voice-port 1/0/0
description - fxo to Call manager
connection plar opx 1000
dial-peer voice 1 voip
description - VOIP calls to call manager
destination-pattern 1000
session target ipv4:
codec g711ulaw
dtmf-relay h245-alphanumeric
ip precedence 5
dial-peer 10 pots
destination-pattern 0
port 1/0/0
Create a H323 gateway in the CM config and give it the name of the router's ethernet IP address.
Create a route pattern of 0.XXXXXXXX where the XXXX's represent the digit string to send out to the PSTN , so each X represents a unique digit.
Point the route pattern to the H323 gateway , and under called party transforms set the discard digits to none, so the called number that hits the gateway router is prepended with a 0. This 0 will be stripped off by the router POTS dial peer, but it will leave the rest of the string intact.
