2801 can not detect VIC3-2FXS card.
I have the 2801 router with a VIC3-2FXS card that is not detecting, I see it with sh diag command like Unkown WAN card.
The IOS that I´m using is:
Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 12.4(15)T7, RELEASE SOFTWARE (fc3)
System image file is "flash:c2801-spservicesk9-mz.124-15.T7.bin"
I checked the details and It can support it.
Do you have any idea what I can do ?.
Thank you, best regards.
Hall of Fame Super Gold
Re: 2801 can not detect VIC3-2FXS card.
For the 12.4(15), you need the Release 12.4(15)XZ with IP Voice feature set.
Note: Please refer to the Cisco IOS Software release notes for determining the minimum flash and dynamic RAM (DRAM) requirements.
Thank you by your support.
Do you know If I can use next IOS:
c2801-ipvoicek9-mz.124-24.T2.bin
Release Date: 22/Oct/2009
Size: 39192.34 KB  (40132948 bytes)
Minimum Memory: DRAM:192 MB  Flash:64 MB
1371
