5300. Using VoIP, and dialup at the time.
How to configure 5300 to works with dialup and voice traffic simultaneously ?
Now I can dial in to 5300.
But when I tried to set VoIP session I get message "Destination out of order" (see debug isdn Q931 command below).
Where is a problem ?
On the other side is CallManager 3.3(2)c.
5300 has a IOS 12.2.15.T8 Enterprise Plus.
Earlier I used 3810 only as a H.323 gateway - it works fine.
Regards.
-- snip --
06:01:46: ISDN Se0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xDD00
Channel ID i = 0xA9839F
Exclusive, Channel 31
06:01:46: ISDN Se0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0xDD00
Cause i = 0x829B - Destination out of order
06:01:46: ISDN Se0:15 Q931: RX <- RELEASE pd = 8 callref = 0x5D00
06:01:46: ISDN Se0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xDD00
-- snip --
Re: 5300. Using VoIP, and dialup at the time.
do you have this http://www.cisco.com/en/US/partner/products/hw/univgate/ps501/products_installation_guide_chapter09186a008007c702.html#xtocid2629912 card installed?
if so, please, show run int SerX/0:15 and dial-peers configs.
Yes.
I have Quad E1 card, Voice DSP card (AS53-VOXD), and Digital modem card.
-- snip Serial config --
interface Serial0:15
no ip address
encapsulation ppp
autodetect encapsulation ppp
isdn switch-type primary-net5
isdn protocol-emulate network
isdn incoming-voice modem
no isdn outgoing display-ie
-- snip config for modem connection --
modem-pool access
pool-range 1-30
called-number 3940 max-conn 10
interface Group-Async1
ip unnumbered FastEthernet0
encapsulation ppp
async mode interactive
peer default ip address pool dialup
no keepalive
group-range 1 30
dial-peer voice 3940 pots
application data_dialpeer
incoming called-number 3940
-- snip dial-peer for voice --
dial-peer voice 1000 voip
destination-pattern 10..
session target ipv4:10.206.1.249
193
