AAL2 Bles loosing conectivity after a few Idle minutes
i have set up an IAD2400 to use VoATM as outlined in the book:"VOAAL2 Profile 9 configuration" and the lines do come up and work as advertised, however; after a few minutes of being idle, we loose connectiviry and the only way of getting it back is to reset the voice ports. The CO voice gateway specifies the following: aal2 Bles mode, Cas-gr303 signaling,CAS refresh every 5 seconds, Idle CAS refreshing enabled and Combined use timer of 20 ms.
I have looked but so far I can't find the setting fo enable the idle cas refresh rate that i suspect is the problem.
please help and thank you in advance
109
