Aalogue Call Problem (weird noises)
Hi Guys,
I have a very basic setup, 2 2600s with a an anologe phones on each.
I make a call from R2 to R1 and I see the H.323 setup and the rtp data, just for an example below.
Thing is, I just get a gabled sound when the call is in progress and I dont seem to be able to speak over the connection.
As you can guess, I am very new to this subject
Config below
router 1
dial-peer voice 1111 pots
destination-pattern 1111
port 1/0/1
dial-peer voice 2222 voip
destination-pattern 2222
session target ipv4:192.168.69.213
router 2
dial-peer voice 2222 pots
port 1/0/1
dial-peer voice 1111 voip
session target ipv4:192.168.69.153
As you can see, I get the H323 setup and RTP data
01:46:40: TCP src=11063, dst=1720, seq=3109389676, ack=0, win=4128 SYN
01:46:40: IP: s=192.168.69.153 (Ethernet0/1), d=192.168.69.213 (Ethernet0/1), le
n 40, rcvd 3
01:46:40: TCP src=11063, dst=1720, seq=3109389677, ack=516277882, win=4128 A
CK
n 115, rcvd 3
CK
n 44, rcvd 3
01:46:40: TCP src=11064, dst=11051, seq=3109445662, ack=0, win=4128 SYN
n 40, rcvd 3
01:46:40: TCP src=11064, dst=11051, seq=3109445663, ack=4054696023, win=4128
ACK
n 44, rcvd 3
ACK
01:46:41: IP: s=192.168.69.153 (Ethernet0/1), d=192.168.69.213 (Ethernet0/1), le
n 40, rcvd 3
01:46:41: TCP src=11063, dst=1720, seq=3109389752, ack=516277943, win=4067 A
CK
n 40, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445667, ack=4054696027, win=4124
ACK
n 89, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445667, ack=4054696134, win=4017
ACK PSH
01:46:41: IP: s=155.195.56.6 (Ethernet0/0), d=224.0.0.10, len 60, unroutable, pro
to=88
n 53, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445716, ack=4054696138, win=4013
ACK PSH
n 44, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445729, ack=4054696147, win=4004
ACK
01:46:41: IP: s=192.168.69.100 (Ethernet0/1), d=192.168.69.255 (Ethernet0/1), le
n 78, rcvd 3
01:46:41: UDP src=137, dst=137
n 59, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445733, ack=4054696147, win=4004
ACK PSH
n 40, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445752, ack=4054696151, win=4000
ACK
n 44, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445752, ack=4054696201, win=3950
ACK
n 63, rcvd 3
01:46:41: TCP src=11064, dst=11051, seq=3109445756, ack=4054696201, win=3950
ACK PSH
01:46:41: IP: s=192.168.69.213 (Null0), d=192.168.69.153 (Ethernet0/1), g=192.16
8.69.153, len 60, forward
01:46:41: UDP src=16596, dst=16426
01:46:42: IP: s=192.168.69.100 (Ethernet0/1), d=192.168.69.255 (Ethernet0/1), le
n 78, rcvd 3
01:46:42: UDP src=137, dst=137
01:46:42: IP: s=192.168.69.213 (Null0), d=192.168.69.153 (Ethernet0/1), g=192.16
01:46:42: UDP src=16596, dst=16426
01:46:42: IP: s=155.195.125.1 (Serial0/0), d=224.0.0.13, len 30, rcvd 0, proto=10
Silver
Re: Aalogue Call Problem (weird noises)
Check out this tool on CCO for voice quality troubleshooting -
http://www.cisco.com/warp/public/788/voice-qos/symptoms.html
give it a try and compare the samples to what you are hearing. If you find a match, you can use the suggestions to clear up the problem.
From your description I think you have a G729r8 pre-ietf codec problem, but give the tool a go and see what you think.
Silver
210
