activate command from phone
Is it perhaps possible that i can activate a command (ios) from a Cisco phone (Callmanager Express) ?
Perhaps by the service button.. or perhaps with a tcl script? so that you call to the AA for example and you can then activate the tcl script..
Something like this...
Thankssss
hello Kennis,
If I understand your question correctly ....you would like to call an AA or a customized tcl  and  you have your phones registered to CME.  Is my understanding of your  issue right ?
If this is right then you can check out  BACD  . You can check this link below....
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html#wp999628
Hope that helps!
Karthik
Yes,that's correct... I would like to activate a self made tcl script that can do some commands on my router
When i call to the acd...
I would check the link...
Thankss
I was also reading something about ixi xml...
is this perhaps some option.. that i activated a xml file from flash with some ios commands in it??
Someone experience with?
i tried some script with commands,no result yet... just saying page not found and nothing happens..
Hall of Fame Super Gold
Re: activate command from phone
I am developing software that will allow to run EEM TCL scripts, from TCL/IVR scripts.
This mean you will be able to call a number from any phone, then via IVR, get authenticate and select which pre-configured action you want to take.
that will be great... however.. is this still on the router it self? so no need for a server?
i want to activate some IOS commands from this script.. is this also then variable? so that i can change the commands my self?
Thanksss
No need for any server, and it can activate any desired config command.
My scripts are developed for commercial purposes, If interested I can be contacted to the email address present in my profile.
956
