Add 9 to calls placed from Call History, CUCM 8.6
I searched on this and found this post:
https://supportforums.cisco.com/message/985700#985700
"In order to have the 9 pre-pended, you have to go to the translation pattern for this user or every user, under the Calling Party Transformations, Prefix Digits (outgoing) add 9 and save it. In order to have the 9 pre-pended, you have to go to the translation pattern for this user or every user, under the Calling Party Transformations, Prefix Digits (outgoing) add 9 and save it."
My question is this: If I make that change will that affect regular outbound dialing when the users are used to dialing the 9?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hey G-Man,
There is a nice step by step guide in this doc;
Add Prefix to the Missed Call Number
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00805b6f33.shtml
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Hey G-Man,
Cheers!
Rob
Thanks Rob!
The only difference is that on CUCM 8.6 the "global" settings are on the gateway configuration and not under the system parameters.
+5
Super Bronze
Ah - well... they are still in service parameters as 'global' settings (hidden in 'advanced' settings).. but you can override them at the device pool, or gateway level. Each of those being more specific in that order...
Device pool makes sense in most cases, global/service params if you're on a single country cluster.
Rob's never wrong :-)
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I don't think I checked the advanced settings.
I should know by now never to question Rob.
Hahahahahahahahahahahahahahaha!!
Re: Add 9 to calls placed from Call History, CUCM 8.6
I am looking for the same answer for the original post.  I want to pre-pend a 9 to the outbound call log so you can redial a number you've already called without editing it.  The answer given above is placing a 9 on the incoming calls, which I have already done.  I want to leave the 9 on the call log of an outbound call.  Any help would be appreciated!
And yes I'm hijacking this post!  Sorry in advance!
Just an update for people who
Just an update for people who were taken here by google.
Tested on CUCM version 9 and 10
http://www.lewan.com/blog/cisco-unified-communications-10.x-adding-prefixes-to-call-history-for-ease-to-users
10480
