Add new E1 to old E1s to have same signal Channel .......???????????.......
i need to add new E1 to be in the same trunk for previous E1 which is for Abdali. new E1 will not have signal it depeneds at old one.
i used this for new E1:
prov-add:nailedtrnk:name="1033",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="33",dsttimeslot="33",spansize=31
for old one this:
prov-add:nailedtrnk:name="1002",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="2",dsttimeslot="2",spansize=30
at AS5400 i used to add new E1:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 1 nfas_group 0
Is this true or there are other commands i should use?
OLD E1 is configured as:
controller E1 7/0
framing NO-CRC4
channel-group 0 timeslots 1
pri-group timeslots 2-31 nfas_d primary nfas_int 0 nfas_group 0
description Connection to Abdali
interface Serial7/0:0
no ip address
encapsulation ss7
channel-id 0
interface Serial7/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-ni2c
isdn incoming-voice modem
isdn map address . plan isdn type network
isdn rlm-group 0
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
isdn bchan-number-order ascending
no cdp enable
please see attached file for more details.
any help please?
1 REPLY
Re: Add new E1 to old E1s to have same signal Channel .......???
That's about it, but you will also need to add the additional trunk to the existing trunk.dat file on the PGW.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/pgw/9/provisioning/notes/NASPKpgw.html#wp1035285
147
