AS5300 and CLID problem
Dear all,
I would like to get help from all the professional here.
I have a cisco as5300 gateway, receiving calls from the as5400 in voip. The calls will be routed to the T1 ISDN interface of my as5300. I want to force the CLID to be sent to the T1 ISDN as a predefined value (let say ... 34567890).
Is it possible to do so ?? Thanks in advance !
Here is my dial-peer configurations:
dial-peer voice 2888 voip
incoming called-number 2888.T
answer-address 34567890
session target ipv4:2xx.xxx.xxx.xxx
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
codec g723r63
dial-peer voice 13 pots
destination-pattern 2888T
progress_ind setup enable 3
progress_ind alert enable 8
translate-outgoing called 2
direct-inward-dial
port 3:D
1 REPLY
Re: AS5300 and CLID problem
use isdn calling-number
on the main isdn interface (ser3:15)
regards,
Andreas
144
