AS5300 ISDN Problem
After getting incoming call from PRI, i get the the error below.
Is a problem only in "Preffered" bit in Channel ID
or in something else?
As i know network side (Telco switch) can set only exclusive bit if this is primary-net5 swicth.
1w0d: ISDN Se1:15 Q931: RX <- SETUP pd = 8 callref = 0x000E
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA1839F
Preferred, Channel 31
Progress Ind i = 0x8283 - Origination address is non-ISDN
Calling Party Number i = 0x1183, 'xxxx'
Plan:ISDN, Type:International
Called Party Number i = 0x91, 'xxxx'
1w0d: VDEV_ALLOCATE: failed to allocate a device
1w0d: VDEV_ALLOCATE_ALMOST_READY: failed to allocate a non-idle modem
1w0d: EVENT_FROM_ISDN: dchan_idb=0x62D7C748, call_id=0x1D, ces=0x1
bchan=0x1E, event=0x1, cause=0x0
1w0d: ISDN Se1:15 **ERROR**: accept_incoming_csm_call: modem problem
Requested circuit/channel not available(0x2C): b channel 30, call id 0x1D
bchan=0x1E, event=0x0, cause=0x0
w0d: ISDN Se1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x800E
Channel ID i = 0xA9839F
Exclusive, Channel 31
1w0d: ISDN Se1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x800E
Cause i = 0x80AC - Requested circuit/channel not available
1w0d: ISDN Se1:15 Q931: RX <- RELEASE pd = 8 callref = 0x000E
1w0d: ISDN Se1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x800E
1 REPLY
Re: AS5300 ISDN Problem
I had the same problem with an AS5350 using IOS from 12.2.13T to 12.3.3a.
Check this bug out :
CSCdz87218
Symptoms: A router may start dropping calls that have the "0x2C" cause code. The cause code indicates that the requested circuit or channel is not available.
Conditions: This symptom is observed on a Cisco AS5300 that has free digital signal processor (DSP) resources.
Workaround: There is no workaround.
Even if on the bug toolkit it says that 12.3.3a is affected, after upgrading to 12.3.3a it worked ok for me... or you can just go back to 12.2 XB :)
293
