ns
AS5350 call routing digit strip
I'm trying to route a call from one PRI connection to another PRI stripping the "00" prefix.
The conf is:
dial-peer voice 1001 pots
destination-pattern ^00%
port 3/7:D
I want to route any call that starts with 00 to port 3/7:D and strip the "00" prefix, but it doesn´t work.
The call doesn´t get routed and the debug output for the ISDN PRI shows that the call gets disconnected because of No circuit/channel available.
Has anyone seen this problem before? We have defined some translation rules for other calls and they work.
Any help is appreciated.
Niels
  • Voice over IP
Re: AS5350 call routing digit strip
try this destination-pattern 00T
try this :
translation-rule 100
Rule 1 ^001.% 1 ANY unknown
Rule 2 ^002.% 2 ANY unknown
Rule 3 ^003.% 3 ANY unknown
Rule 4 ^004.% 4 ANY unknown
Rule 5 ^005.% 5 ANY unknown
Rule 6 ^006.% 6 ANY unknown
Rule 7 ^007.% 7 ANY unknown
Rule 8 ^008.% 8 ANY unknown
Rule 9 ^009.% 9 ANY unknown
translate-outgoing called 100
port 3/7:D
Or, if you have fixed size numbers like 0012341231231 you can skip the translation-rule and use forward-digits on the dial-peer.
However, I recommend using translation-rule.
ns
Thanks for you replies.
Niels
260
