AS5350 DTMF works fine from external but not from PBX
When calling into from an external Phone line (Cell phone,etc) the DTMF works great, every time.
From my office using a ROLM phone dialing out into the Gateway it picks up fine, but the DTMF tones are not recognized but sometimes it is. It is intermittent. I suspect an IOS level related issue. If this is the fix, can you informed me of what IOS level is required to fix the DTMF problem using a PBX.
See attachments for version and running-config.
Re: AS5350 DTMF works fine from external but not from PBX
The IOS version is Experiemental Version as it appears, Can you try a stable Validated IOS
Lets say 12.3(11)T7 for example
thanks
Can I use c5350-is-mz.124-6.T11.bin ? And if I can, do I need to install another boot flash file or can I use whatever I have.
I believe I have only 32mb of flash. Will the above IOS be ok to use?
Thanks for all your help.
-Al-
You can use this IOS but This IOS has a min Flash of 64MB and DRAM capacity of 256MB
160
