05-20-2003 10:12 PM
I have a Cisco As5350 voice gateway with 4 E1 interface. It coneects to a remote AS5300 gateway by Internet . When the as5300 sends a fax to as 5350 ,it's ok ! But when as5350 sends one to as5300 , it will disconnects when they are handshaking .
The as5350 is configured as fax protocol t.38 & fax rate voice & fax-relay ecm disable.
What's the problem ?
Solved! Go to Solution.
05-27-2003 10:50 AM
The as5350 can work with T.38 only, hence you have to configure as5300 with T.38. And you also need to configure the incoming dial-peer on the as5300 as T.38
The additional configuartions on as5300 should be :
dial-peer voice 200 voip
incoming called-number .T
fax protocol t38 ls-redundancy 0 hs-redundancy 0
Also check if the codec and the clocking and compression techniques used are same, on both the ends.
05-27-2003 10:50 AM
05-27-2003 03:51 PM
Thank you for your reply .
I did configure as5300 with T.38 but did not confiure as5300 as t.38.
I will try it .
Thank you
05-28-2003 10:52 AM
Jeremy,
did you try the configuration change, and did it fix the problem? I have seen an issue similare to this one, but didn't know how to resolve it.
Iris,
is this a known issue/difference between the 5300 and the 5350? i would like to know more about what specific command/feature causes the fax failure. any more elaboration you can add to your already-interesting comment would be really appreciated.
E.
05-28-2003 04:26 PM
Yes , I configured both the gateways as T.38 and it worked.
