AS5350 Tone Genertion
I have an AS5350 that is accepting H323 calls from the ethernet side and transiting them to an ISDN line.
I am trying to get an AS5300 to generate the ringing tone, but it only works if disable early h245 and fast start on my softphone.
Does anyone know if there is anyway if these can be blocked at the as5350?
T
1 REPLY
Bronze
Re: AS5350 Tone Genertion
Not sure of what you want to do - make the 5350 play ringback to the H.323 softphone or block that? Typically in such scenarios, ringback should come from the ISDN switch - check the below link for ringback options:
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
120
