AS5400 problem
kyleeot75
Hello
I am sending call from a Nextone SBC to an AS5400. The AS5400 is routing the call but not putting any CDN into the ISDN setup message even though the incoming invite has the TO header populated with the number
I compared a good call to a bad and what I did notice is that the bad calls TO header looks like this coming into the 5400
To: 011861085208666<sip:011861085208666@38.117.159.235:5060>
A good call looks like this
To:<sip:011861085208666@38.117.159.235:5060>
Could the 5400 have a problem with the double format ? Has anybody seen this before ?
Here is the trace from the 5400 and you notice the CDN field is not populated in the outgoing ISDN setup.
Received:
INVITE sip:011861085208666@38.117.159.235 SIP/2.0Max-Forwards: 69Session-Expires: 3600;Refresher=uacSupported: timer, 100relTo: 011861085208666 <sip:011861085208666@38.117.159.235:5060>From: .2127962106. <sip:2127962106@38.117.156.82>;tag=3405179539-136721Call-ID: 212-3405179539-136713@NTSBC1.defaultdomainCSeq: 1 INVITEAllow: INVITE, BYE, OPTIONS, CANCEL, ACK, REGISTER, NOTIFY, INFO, REFER, SUBSCRIBE, PRACK, UPDATEVia: SIP/2.0/UDP 38.117.159.146:5060;branch=z9hG4bKb65d5ae8d1e40a74ebd594e0e6e1e0a7Contact: <sip:2127962106@38.117.159.146:5060>Call-Info: <sip:38.117.159.146>;method="NOTIFY;Event=telephone-event;Duration=1000"Content-Type: application/sdpContent-Length: 195v=0o=NTSBC1 2147483647 2110921806 IN IP4 38.117.159.146s=sip callc=IN IP4 38.117.159.147t=0 0m=audio 11810 RTP/AVP 0 18 4 2 2a=fmtp:18 annexb=noa=rtpmap:2 G726-32/8000a=ptime:20
Nov 27 19:12:19.100: ISDN Se1/0:28:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 2127962106
Nov 27 19:12:19.100: ISDN Se1/0:28:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Called num
Nov 27 19:12:19.100: ISDN Se1/0:28:23 Q931: TX -> SETUP pd = 8 callref = 0x56F6
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2180, '2127962106'
Plan:ISDN, Type:National
Called Party Number i = 0x80
Plan:Unknown, Type:Unknown
8 Replies 8
paolo bevilacqua
I think there should be a space before < in the below, typo ?
To: 011861085208666<011861085208666>
Actually, it is not necessary: (http://tools.ietf.org/html/rfc3261#section-20.10) There may or may not be LWS between the display-name and the "<".
kyleeot75
There is a space
That was a typo
Here is what my dial peer looks like. Can figure out why the 5400 is not translating this tothe ISDN side and sending a NULL CDN to my gateway
dial-peer voice 28 pots
destination-pattern 011861085208666
port 1/0:28:D
andrew_pog
Does 'debug ccsip error' reveal anything?
nothing shows up on the degub ccsip error or debug isdn q931 error
The thing is this TO header format is being sent out to a SIP peering provider of mine and they are not having an issue with it. Only the 5400. It does not populate a CDN parameter in the ISDN setup message to my PSTN switch
Which exact IOS are you using ?
I found the issue
This is what my dial peer looked like
shutdown
port 1/0:28:D
Here is what is looks like now
shutdown
port 1/0:28:D
Now the call works ! ?? The CDN is being placed into the ISDN setup properly
Bug ?
Is there a digit timer command I am missing here ?
Cisco IOS Software, 5400 Software (C5400-IS-M), Version 12.4(16), RELEASE SOFTWARE (fc1)
Well, pots DP by default absorbs digits matched in destination-pattern, so configured like it is now, it should send 85208666 as called number.
This behavior can changed with "forward-digits" and "digit-strip" commands.
