03-01-2004 02:48 PM
I am needing a fax solution cheap for a customer I have two ATA186 devices. When I browes into them what is the default password? Also what is the easy way to upgrade I am at 2.16. Do they still have faxing issues in the 3.0 version.
03-02-2004 01:47 AM
Try typing password as admin and leave the username empty.
If this doesn't work, try factory reset.
With respect to Fax, This link will give a good pointer for the Fax features in ATA's.
http://www.cisco.com/warp/public/788/ata-fax.html
Hope this helps
Santosh
03-02-2004 06:36 AM
thx
