05-28-2012 02:40 AM
I have problems with my ATA box 187.
it is plugged into my version of CUCM 8.0.3.20000-2
I declared a new device (Cisco ATA187) which I connected an analog phone. Until then, no problem. I can emit and receive calls from inside and outside.
I now wish to fax in place of my analog phone and there problem: nothing works, I see the start of communication between two fax but no data.
I tried Fax passtrought and T.38 Fax passtrought
here is a
term mon / debug isdn q931 show :
May 28 09:11:52.005: ISDN Se0/1/1:15 Q931: TX -> SETUP pd = 8 callref = 0x00CD
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839E
Exclusive, Channel 30
Calling Party Number i = 0x0081, '491563695'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '0491562008'
May 28 09:11:52.109: ISDN Se0/1/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x80CD
May 28 09:11:53.013: ISDN Se0/1/1:15 Q931: RX <- PROGRESS pd = 8 callref = 0x80CD
Cause i = 0x87F2 - Unknown cause value
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
May 28 09:11:53.013: ISDN Se0/1/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x80CD
May 28 09:12:15.459: ISDN Se0/1/1:15 Q931: RX <- CONNECT pd = 8 callref = 0x80CD
May 28 09:12:15.463: ISDN Se0/1/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x00CD
May 28 09:12:52.875: ISDN Se0/1/1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x00CD
Cause i = 0x8090 - Normal call clearing
May 28 09:12:53.159: ISDN Se0/1/1:15 Q931: RX <- RELEASE pd = 8 callref = 0x80CD
May 28 09:12:53.179: ISDN Se0/1/1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x00CD
what other actions should I take?
Sincerely,
05-28-2012 03:25 AM
i add my CUCM conf
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.xxxx
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.xxxx 192.168.xxxx
ccm-manager config
mgcp
mgcp call-agent 192.168.xxxx 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp fax rate 14400
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
