Community Member
ATA188 CVOICE
I want to set up some analogue phones in a lab for CVOICE and have a ATA188. Can this be setup on a 2821 router without CCM?
VIP Purple
Re: ATA188 CVOICE
One way to do this is to load the H.323 image on the ATA and register it to a gatekeeper on the 2821.
Brandon
Community Member
Re: ATA188 CVOICE
You can install using CCM Express on 2821 & register your ATA 188 with it is will give the same functionlity what you can get with ccm
& definetly another ways is using H323 firmware image in ATA 188 and install gatekeeper on 2821
that also will work
3rd option also is there if u have sip server which you can install on pc & on ata 188 use sip firmware on that then also it will work
regards,
Deepak Maheshwari
165
